Recommended IOS - Switches - 3850 - 3650 stacks
kumarpillaiwg
Hi All
im looking for comprehensive list of Cisco IOS  supported by APIC-EM PnP, in the middle of EoL refresh so want to get this right if i can.
looking @ 3650 stacks and 3850 stack, any input on what IOS  should go for with PnP support will be much appreciated
Thanks in advance
Kumar
aradford
release notes are the best bet.  Practically speaking, 3.6.5 is best release.  Particularly if you are using non-vlan 1 for management.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Plug-and-Play/release/notes/pnp-release-notes12.html
aradford
depending on your deployment model you can take a look at the following blog. I have a couple more to do, including stacking.
Common Deployment models for PnP - blog
