Register an unregistered switch
m.yost
Is it possible to use the acitoolkit to register unregistered switches to the fabric?  From what I can tell, a switch doesn't become a Node until it is registered....I just can't find a way to do this with actitoolkit or by using Cobra.
Assuming a brand new Fabric, APIC will only see the leaf it is directly attached to under Fabric Membership.  From here, you need to register the node by giving it a node ID and a name.  From there you will find the spines and once you add the spines, you find the rest of the leaves.  I would like to automate this discovery and register process....I just can't figure out how to register that first node!
0 Replies 0
