ygorelik
I am happy to announce general availability of NSO Sync Monitor package on the GitLab.
The NSO Sync Monitor is targeted to monitor sync status of managed network devices and proactively check
and perform bulk device synchronization. It is designed to work as plug-in package, which can be installed
and used in customer based NSO installations.
The snmp sync-monitor service enables monitoring of configuration changes on specified devices. It also configures
devices to send SNMP or Netconf notifications to NSO. Here is the list of NEDs, which are currently supported by SNMP
sync monitors:
- cisco-ios-cli
- cisco-iosxr-cli
- cisco-iosxr-nc, starting from release 7.5 and devices with IOS XR 7.5.1
- juniper-junos-nc
Although Netconf enabled NEDs support notifications, the real Cisco and Juniper devices are not. Hence, use of Netconf
sync monitors is now limited only to tests on Netsim devices.
The sync monitor package includes number of actions, they are:
- device-action - allows to run check-sync, sync-from, and sync-to NSO device actions on multiple devices
- status - shows current status and configuration of sync-monitor
- change-status - enables, disables or deletes sync monitors of specified type; it also clears operational data
- netconf-action - invoked by netconf-action-kicker when Netconf notification arrives to NSO
- snmp-action - invoked by snmp-action-kicker when SNMP notification of device configuration change arrives to NSO
The functioning sync monitor collects operational data, which can be viewed by the user to analyze history of device configuration changes.
3 Comments
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
