Nicklas Wagerth
Community Manager
Community Manager
Crosswork Router Automation Kit Part 2: Golden Configuration Templates
Automation Developer Days US, Dec 6, 2023
Abstract: The Golden Config Templates feature combines the NSO device template functionalities with other frequently used NSO features such as check-sync, dry-run, audit, and FastMap. These are essential for daily operations. The golden config facilitates the storage of templates and allows certain parameters to be set as variables in the Jinja template format. It also provides flexibility in terms of device configuration formats, supporting native, c-style, j-style, json, and xml formats. Moreover, this feature is accessible via the Workflow Manager.
Link to recording
Speaker: Niraj Chandak, Software Engineer, Cisco
Niraj ChandakNiraj Chandak
Co-Presenters (Live): Wai Tai, Senior Software Architect,
Ravichandran Venkataraman, Technical Marketing Engineering Technical Leader
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
