Nicklas Wagerth
Abstract: Cisco Crosswork Network Controller (CNC) supports out of box visualization of VPN Services and associated Traffic engineered underlay paths for the supported out of box NSO packages - the TSDN Core Function Packs. This session discusses how to make extensions of this to support variations of this service and multivendor extensions. Besides modifying the NSO implementation, the visualization model needs to be updated using the Crosswork SDK. And finally the service health monitoring rules automatically convert the service instance config data into an assurance model which can be extended for multi-vendor. This session will cover the key areas of extensions in CNC.
Speaker: Krishnan Thirukonda, Principal Engineer, Cisco
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
