imrbaig
Do you have network configuration compliance issues?
If the answer to this question is “yes” then you may have an easy solution through NSO (Network Service Orchestrator).
Cisco CX team has developed an NSO-based package that can report and fix non-standard configuration on device(s) in your network.
What are the supported Platforms
Currently out of the box, Cisco ISO, IOS-XE, IOS-XR, Juniper platforms has been validated.  More platforms (including multivendor OScan easily be validated by just defining golden templates for those platforms/vendors.
Available Features:
  1. Open architecture: Generic platform to support reporting and resolving configuration issues. More device vendors can be easily added.
  2. Extensible YANG model: Existing YANG model can be extended to support customizations.
  3. Multiple templates support: Can generate reports for multiple golden templates.
  4. Devices compliant support: Option is available to make device(s) compliant against given golden templates.
  5. Bulk device(s) support: You can identify and fix golden configuration in bulk for same or different devices.
For further information please contact the Cisco Advanced Services team, Syed Ziaullah (sziaulla@cisco.com), Solution Architect, Manish Jain (manisjai@cisco.com), Director Software Integration and Orchestration.
Note: Please login to this site if you cannot play the video
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
