Crosswork Automation Hub Videos
News and Announcements
Great to see TIM and Paolo Fasano’s team driving digital transformation and efficiency with NSO—an inspiring example of how automation empowers organizations to stay agile and deliver better services. Learn more about TIM's Automation Journey in this knowledge article.
Introducing Cisco NSO 6.6: featuring an integrated AI Assistant in the web UI, a new concurrency-optimized Resource Manager, improved YANG schema management, enhanced High Availability and Compliance Reporting tools, updated example NEDs, and advanced service consistency checks. See blog post for more info!
To enhance the quality of NSO product, we invite you to share your insights and suggestions by participating in our short survey based on your NSO experience. Your input directly shapes the future of NSO. Klick on the image or scan the QR code to get to the survey!
Blog Articles
OS Upgrade Version 2 using NSO
Do you need to upgrade the OS on your infrastructure devices?   If the answer to this question is “yes” then you may have an easy solution through NSO (Network Service Orchestrator). Cisco Advanced Se...
4 Comments
Network Configuration Compliance Using NSO
Do you have network configuration compliance issues? If the answer to this question is “yes” then you may have an easy solution through NSO (Network Service Orchestrator). Cisco CX team has developed ...
0 Comments
Pioneer NED Builder
This video shows a demo of using the NSO Pioneer NED builder tool to build a NETCONF NED for a new device. The script that was used in the demo is attached (build-and-install-ned.sh).
4 Comments
How to automate port turnup with NSO
Do you need to automate port turn up in your network?   If the answer to this question is “yes” then you may have an easy solution through NSO (Network Service Orchestrator). Cisco Advanced Services h...
4 Comments
Automating compliance reporting & remediation using NSO
Do you have devices in your network which are not compliant with your network standards?   If the answer to this question is “yes” then you may have an easy solution through NSO (Network Service Orche...
4 Comments
NSO Dev Days: Netrounds demo
Stefan Vallin of Netrounds demonstrates the integration between NSO and Netrounds on the NSO Developer Days 2018   Watch recording on YouTube: https://www.youtube.com/watch?v=bQwEVnaFkYw
0 Comments
Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the NSO Developer community:
