hdihd9162
Description of the problem
In the architecture that can be seen in the figure below, we have two switches of the same type that are connected to each other with a number of links. The links in question are configured as port channels on each switch. According to the Cisco document, there is a feature called symmetric load-balancing to distribute the load between the links in a port channel. This feature works in such a way that the traffic that is balanced on a port according to the algorithm will always be balanced on the same port. The remarkable thing is that this behavior is the same in both switches. That is, when "Traffic One" on "Switch One" is balanced on the second link, it will forever pass through this link. Also, in both switches, this traffic is balanced on the same link.
The problem arises when these two switches are under load, after a period of time has passed and by performing a large number of shots and writing ports, this symmetric mode is lost, and in this case, the traffic of one that was previously on switch one It used to be on link two, now it is on link three, and the worse thing is that this traffic on switch two is placed on a link other than three, and server-to-client and client-to-server traffic sessions pass on different links. This is if both sides of the meeting used to pass through Link 2).
The point is that sometimes after shooting and writing the port channel, the problem is solved and the switches send the traffic correctly again.
elahe
I have a similar problem that traffic from one flow (same ip and port and same po load balance algorithm) goes from different egress links in two different switches. It gets even worse when using vPC and more than two switches. If you could find a solution, please inform me too. I deeply appreciate it in advance.
ggorrell
I am curious what the actual issue is here.  Unless the feature states that this is a permanent pinning, then there is no concern.  Further, why would it matter on which link the client and server traffic traversed?
