libxu
Hi: all
      I have a route leaking question on N7K VRFs. I created two VRFs on N7K, and need to control the route leaking between them. I successful did it with "export map  ****" command, but when I use the "import map ****", it is not working. from the NX-OS MPLS configuration guide, I read there should be a "import statement" configured to enable the route-map filtering, but I don't understand what the "import statement"  is, could anyone give a hint?
     Thanks very much.
     The software version is 6.1(1), and the configuration guide I refer to is:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/mpls/configuration/guide/mp_vpn_l3vpn.html
