07-18-2020 03:57 PM
I have 2 EPGs,
EPG A has a single host(virtual appliance) with IP of 10.1.1.1, BD Subnet 10.1.1.0/24.
EPG B has 50 hosts in the IP range 10.2.2.0/24 configured on BD subnet.
How can i use contracts to limit communication from EPG A to only 4 hosts in EPG B [10.2.2.5, 10.2.2.6,10.2.2.7,10.2.2.8].
Is that possible?
Rohan
07-18-2020 08:09 PM
07-19-2020 12:52 AM
Hi Francesco
My query is how can i use contracts to limit communication from EPG A to only 4 hosts in EPG B [10.2.2.5, 10.2.2.6,10.2.2.7,10.2.2.8] and not the whole EPG B.
Is that possible, or would i have to break up EPG B into smaller EPGs to do that?
Rohan
07-19-2020 06:29 PM
07-19-2020 10:07 PM - edited 07-19-2020 10:12 PM
You can create a uEPG containing 10.2.2.5, 10.2.2.6,10.2.2.7,10.2.2.8, and you can apply the contract between the uEPG and EPG-A.
For everything else regarding policy enforcement on uEPG, you can inherit the contracts from EPG-B.
For more details about micro-segmentation, have a look on the config guide and ciscolive presos:
https://aci-lab.ciscolive.com/lab/pod21/segmentation/mseg
Stay safe,
Sergiu
07-26-2020 05:43 AM
Hi Sergiu
In case of micro segmentation the 4 hosts in epg b which are part of the uEPG will not be able to communicate with rest of EPGB members. Is that right?
My requirement is to make sure EPGA can only talk to some members of EPG B. The only possible solution seems splitting up EPGB into smaller epgs.
Rohan
07-28-2020 06:29 PM
07-30-2020 01:36 AM
That is correct. You will need contracts if you need communication between uEPG and base EPG.
Stay safe,
Sergiu
