03-22-2020 08:43 AM
As per Cisco document below is the ACI discovery flow:-
1. LLDP Exchange
2. TEP through DHCP
3. ISIS protocol Adjacency
4. certification validation
5. DME start
When Image will be upgraded in the process flow? Is it before ISIS adjacency or after certificate validation?
03-22-2020 07:39 PM
03-22-2020 08:46 PM
Thank you very much for your reply.
But I didn't find any cisco document related to it and does anyone have any cisco document explaining it? There are few documents including ciscolive but I couldn't see the full discovery flow.
I want to know, without ISIS neighborship how the remote switch has the reachablility to the APIC and which IP address it uses to reach APIC?
03-22-2020 09:25 PM
Also how without certification validtion, APIC is providing image to the switch and allowing control plane (ISIS) up?
03-24-2020 02:54 AM
ACI nodes are not upgraded during ACI Fabric discovery. There is a software validation check which is done, but this is not performing any upgrades/downgrades.
You can trigger an upgrade of ACI leaves/spines only after the nodes are registered with APIC and are in-service state. More details about the upgrade can be find here: https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/all/apic-installation-upgrade-downgrade/Cisco-APIC-Installation-Upgrade-Downgrade-Guide/Cisco-APIC-Installation-Upgrade-Downgrade-Guide_chapter_011.html
Cheers,
Sergiu
04-13-2020 11:43 AM
thank you for your answer and it make sense as well. Can you please tell me what is the complete leaf discovery flow?
04-13-2020 12:52 PM
The basic steps of fabric discovery process are as follows:
Reference: https://www.booksprints.net/book/the-second-aci-troubleshooting-guide/
Cheers,
Sergiu
