C9300L-24T-4G-E built-in 1G SFPs (SM or MM ?)
cristiantudor
Dear Community,
After the purchase of this switch i am not sure if the 4 buit-in 1G SFP connectos supports singlemode or multimode lc connectors.
The data sheet is confusing.  I can understand that it supports both of them. Is that true? Could someone help me please?
m.kafka
Level 4
Level 4
Hi Cristian,
the SFP ports can be equipped with any Cisco transceiver: single mode, multi mode or copper. "Fixed" only means, that the uplink SFP receptacles are not modular (on other models you can choose uplink, e.g. SFP, SFP+). You have to order the transceivers extra.
Rgds, MiKa
