Can a Nexus 9336PQ Switch run nxos code?
I have 2 Nexus 9336PQ switches that I want to put nxos code on so they aren't in ACI mode.  I've downloaded nxos.7.0.3.I7.3.bin and tried to put that code on the switches. I did this because I couldn't find any images that start with nxos under the download section for my switch.  Is there a way to make the switch not be in ACI mode?  Is there a command I can issue to make this happen or do I need another image?
Thanks for your help!
DominikPecak
Level 6
Level 6
Nexus 9336PQ supports only ACI mode.
Thank you!
