can anyone help me out ?? how can i create portchannel(lacp) b/w nexus 9k and cisco 3750
DeepakKumar6006
8 Replies 8
Hello
You don’t mention how is this 9k connected - Is it in a vpc domain or stand-alone, are you suing single/multiple VDC's-do you have any fex attached etc...?
If its in a vpc with default vdc then after you've created the vpc domain you just then create the PCs as you would do any other LACP PC on both 9k switches and append a vpc index to each PC to tie them together
Both 9ks
feature lacp
feature vpc
int port x
switchport mode trunk
vpc x
if it’s a standalone 9k then no need for any vpc
On the 3750 just a normal PC is required
Kind Regards
Paul
it is a standalone device which is connected to a non cisco device
L3 switch config-
interface GigabitEthernet1/1
media-type rj45
no negotiation auto
channel-group 10 mode active
interface GigabitEthernet1/2
media-type rj45
no negotiation auto
Group Port-channel Protocol Ports
10 Po10(SN) LACP Gi1/1(w) Gi1/2(w)
Nexus 9k config
interface port-channel10
interface Ethernet1/1
interface Ethernet1/2
Group Port- Type Protocol Member Ports
Channel
10 Po10(SD) Eth LACP Eth1/1(s) Eth1/2(s)
still the issue is not resolved
Hello
Well then it will just be a normal L2 PC config.
Have you enabled lacp on the 9k?
example: 9k
feature lacp
default interface x/x -x
interface x/x-x
switchport
channel-group x mode active
int port x
swithport mode trunk
Kind Regards
Paul
As you can see in nexus config the protocol is LACP
Hello
i understand that but to use lacp in nxos you need to enable it so did you enable?
show feature
Kind Regards
Paul
switch(config)# show feature
Feature name  Instance    State
l2vpn              1              disabled
lacp                1              enabled
ldap                1              disabled
ldp                  1              disabled
So you need to decide what type pf PC this is going to be - L2 or L3
As you have not stated this but it seems the 9K is connecting to a 3750 switch I would assume its going to be a trunk?
Now providing the physical connections are compatiable with each other, (meaning you have the correct copper or SFP modes, cabling etc..) the configuration should be as follows:
3750
show interface x/x capabilities < need to be compatible with the 9K interfaces)
no int port 10
default interface range gig1/1 -2
shut
switchport
int port 10
swutchport trunk dot1q encap
no shut
exit
9k
show interface x/x capabilities < need to be compatible with the 3750 interfaces)
feature lacp
default interface et1/1 -2
interface et1/1 -2
shut
swithport
exit
int port 10
interface et1/1 -2
no shut
Kind Regards
Paul
