03-12-2023 09:03 PM
My DC Switch is N9k-9372TX x2 device is VPC Peering
I want to Migrate N9K-9372TX to N9K-93108TX-FX3P
I need to minimum downtime for upgrade
Can I move nexus one by one by use N9K-9372TX peer with N9K-93108TX-FX3P
Solved! Go to Solution.
03-13-2023 12:19 AM
Hi @patiphan-OH
No, you cannot mix different generations of Nexus switches into the same VPC domain.
Take care,
Sergiu
03-13-2023 12:19 AM
Hi @patiphan-OH
Take care,
Sergiu
03-13-2023 06:06 AM
Hello!
@Sergiu.Daniluk is absolutely correct here - both Nexus switches that form a vPC domain must be of the same generation. Furthermore, Cisco only supports a vPC domain where both Nexus switches are the exact same model. This is called out under the "Guidelines and Limitations" heading of the "Configuring vPCs" chapter in the Cisco Nexus 9000 Series NX-OS Interfaces Configuration Guide document:
"When forming a vPC domain between two Cisco Nexus 9300 Series switches, both switches must be the exact same model to form a supported vPC domain. When forming a vPC domain between two Cisco Nexus 9500 Series switches, both switches must consist of the same models of line cards, fabric modules, supervisor modules, and system controllers inserted in the same slots of the chassis to form a supported vPC domain."
I hope this is helpful - thank you!
-Christopher
