cannot access 1010 via SOL(serial over LAN)
miwitte
Level 4
Level 4
SO I have a pair of 1010's that I want to migrate our VSM's over to. I have everything sertup properly in the CIMC GUI(remote precense). Basically if I connect via the CIMC GUI and try the KVM I get the console is blocked error(which I read is normal) Conneting via the console itself I dont get anything and if I telent to the CIMC and then do a "connect host" it says "booting from hard disk" HW is "NEXUS1010" and "done". If I reboot the server you can see everything boot and you get the box where you can choose the 1010 but then nothing.
0 Replies 0
