Cannot access to Nexus switch via console
tuanquangnguyen
Hi folks,
Running into an issue with one of the N9K-C93180YC-EX switches, where I cannot access to the switch via its console port.
The two switches were purchased in the same contract, and are recently racked and stacked to prepare for new services. While I can access one of them normally, the other would neither respond to any input nor would it output anything to the terminal. I have tried all possible baud rate (9600, 115200 then anything really).
Since the switches are new and do not have their IP configured, I cannot check for the running NX-OS on the faulty switch, nor can I SSH to it.
Has anyone encountered the same issue?
Sergiu.Daniluk
Maybe is DOA. Do you see any LEDs blinking?
Sergiu
Sergiu.Daniluk
Sergiu
It was a DOA RMA case
