Cisco Catalyst 9500 Series Switches
aldaf3i
Dear Sir,
I would like to order Catalyst C9500-24Y4C switch, but I found that there are (24Y4C-A, 24Y4C-E, 24Y4C-EDU).
Could you please tell me the differences between them ?
Best Regards,
shaps
Level 3
Level 3
I believe they related to the new licensing scheme cisco is introducing, A = Advantage E = is Essentials, I believe they can be looked at as A is akin to Lan base and the E is like the IP services image.
I have a C9500-24Y4C , and i need to install ios cat9k_iosxe.16.06.05.SPA.bin
The procedure is
copy usbflash0: flash:
then,
install add file flash:cat9k_iosxe.16.06.05.SPA.bin activate commit
reloads
It supposed to take the new ios code, instead it keeps rebooting
I have to go to rommon to load the original ios code that comes with the switch:cat9k_iosxe.16.09.03.SPA.bin
I tried to also change the bootflash to packages.conf and cat9k_iosxe.16.06.05.SPA.bin and it keeps rebooting
config t
boot system bootflash:packages.conf
or
boot system bootflash:cat9k_iosxe.16.06.05.SPA.bin
and also
no boot system bootflash:cat9k_iosxe.16.09.03.SPA.bin
not sure if this switch is not compatible with this 16.6.5 version or I'm missing something.
