Cisco Nexus 3548 - Stuck in loader> after failed upgrade
norsar
Hi!
Trying to upgrade to 9.2.4.
# sh run | inc boot boot kickstart bootflash:/n3500-uk9-kickstart.6.0.2.A8.9.bin boot system bootflash:/n3500-uk9.6.0.2.A8.9.bin # copy tftp://x.x.x.x/n3500-compact.9.2.4.bin bootflash: # dir | inc bin 530509806 Dec 16 22:46:51 2024 n3500-compact.9.2.4.bin 36825088 Oct 19 06:35:21 2016 n3500-uk9-kickstart.6.0.2.A7.2.bin 37681664 Jun 22 18:41:28 2020 n3500-uk9-kickstart.6.0.2.A8.9.bin 181796339 Oct 19 06:36:07 2016 n3500-uk9.6.0.2.A7.2.bin 196631322 Jun 22 20:18:52 2020 n3500-uk9.6.0.2.A8.9.bin 454724432 Jun 22 21:35:06 2020 nxos.7.0.3.I7.6.bin # show file bootflash:n3500-compact.9.2.4.bin md5sum c77ca5ea11271d3ba12525ce1b34994a # conf terminal # boot nxos bootflash:/n3500-compact.9.2.4.bin # copy running-config startup-config # sh run | inc boot boot nxos bootflash:/n3500-compact.9.2.4.bin boot system bootflash:/n3500-uk9.6.0.2.A8.9.bin # reload Forgot to remove old boot command and got stuck in loader: loader> Booting kickstart image: bootflash:/n3500-compact.9.2.4.bin ............................................................................... ............................................................................... error: Failed to allocate chunk. loader> Trying to boot from old kickstart image: loader> boot bootflash:/n3500-uk9-kickstart.6.0.2.A8.9.bin Nexus is stuck, need to powercycle... loader> help ? Print the command list boot Boot an image dir List the directory contents or specific file help Print the command list or the specific command usage reboot Reboot the system resetcmos Reset CMOS to factory defaults serial Serial console settings set Set network configuration show Show loader configuration Unable to list contents of FAT32 formatted USB drive on usb1: & usb2:, no such device. Set IP-address, but unable to ping and no traffic seen when trying to do boor from tftp:// Suggestions???
marce1000
                         >....error: Failed to allocate chunk.
  - That could point to memory fragmentation , it looks not applicable in this context , but could you also
     try a power cycle of the nexus first ?
 M.
Rebooted several times. The Nexus freezes when I try to run boot commands from the loader> prompt.
Tried to boot using the different images on bootflash:, they all freeze
  - Could you try to execute the procedure as explained in : https://www.youtube.com/watch?v=JskVWVY5U00&t=92s
     (of course parameters could change , such as the os version you want to install).
    M.
This Video uploaded for better access on the main video. Main Link of this video is here. https://supportforums.cisco.com/t5/data-center-videos/how-to-restore-a-cisco-nexus-switch-from-loader-prompt/ba-p/3101970 Original link video seems to BW limitation enabled. This great video helped me to ...
Dawei
1. Please use the "install all" command to upgrade NXOS instead of changing the boot variable.
2. Please refer to the following documentation to follow the upgrade path: 6.x -> 6.0(2)A8(11b) -> 7.0(3)I7(9) -> 9.3(x).
https://www.cisco.com/c/en/us/support/docs/ios-nx-os-software/nx-os-software/216492-upgrade-nexus-3524-and-3548-nx-os-softwa.html#toc-hId-1964032160
