Cisco Nexus 5672UP SFP/Interface speed
farispv
Dear Team.
I would seek your kind advise and help to resolve below issue which am facing.
Am, configuring 10G SFP connection on Nexus switch (5672UP), the interface shows the status SFP validation failed and interface not getting up. I have changed SFP and connected same SFP on another interface on same the Same SFP works fine with 10Gbps.
I checked the interface status and switch default configuration, the interface transceiver capability shows 1000/10000 and SFP Media Type SFP-1000BASE-T and slot configuration shows global in switch
slot 1
port 1-48 type ethernet
The subjected Interface previously connected SFP-1000BASE-T ethernet cables with speed 1000. I have changed interface speed. but the still not getting up.
I have attached here the switch configuration and the subjected Interfaces status and some other active 10G interface details as well.
I would be grateful on your help and advise to sort out this issue which am facing.
Thank you.
Config summary
====Run Config===
slot 1
cor-DC# show interface ethernet1/24
Ethernet1/24 is down (SFP validation failed)
Dedicated Interface
Hardware: 1000/10000 Ethernet, address: 00de.fb5e.fabf (bia 00de.fb5e.fabf)
Description: "Connected HP"
MTU 1500 bytes, BW 10000000 Kbit,, BW 10000000 Kbit, DLY 10 usec
Encapsulation ARPA, medium is broadcast
Port mode is access
full-duplex, 10 Gb/s, media type is 1G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped 2week(s) 3day(s)
Last clearing of "show interface" counters 2w3d
76 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output error 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
Eth1/21 -- connected 50 full 10G 10Gbase-SR
Eth1/22 -- connected 50 full 10G 10Gbase-SR
Eth1/23 -- sfpInvali 50 full 10G SFP-1000BAS
Eth1/24 -- sfpInvali 51 full 10G SFP-1000BAS
Eth1/25 "Connected to HP-E connected 51 full 10G 10Gbase-SR
Eth1/26 ****Connected to C connected 50 full 10G 10Gbase-SR
Eth1/27 -- connected 50 full 10G 10Gbase-SR
Ethernet1/23
transceiver is present
type is SFP-1000BASE-T
name is CISCO
part number is SP7041-TE
revision is A1
serial number is MTC210204CS
nominal bitrate is 1300 MBit/sec
Link length supported for copper is 100 m
cisco id is --
cisco extended id number is 4
DOM is not supported
Ethernet1/24
name is CISCO
revision is A1
serial number is MTC210204WX
cisco id is --
0 Replies 0
