Cisco Nexus 9000 N9K-C983180YC-EX temp sensor guide
melfab841
Can you provide what should be the normal temp sensor threshold for cisco nexus 9000 N9K-C983180YC-EX? Thank You.
Is the sugarbowl CurrentTemp ok? because 58 degree celcius is equivalent to 136 degree farenheit
Temperature:
Module   Sensor        MajorThresh   MinorThres   CurTemp     Status
                       (Celsius)     (Celsius)    (Celsius)
1        FRONT           80              70          34         Ok
1        BACK            70              42          33         Ok
1        CPU             90              80          43         Ok
1        Sugarbowl       100             90          58         Ok
giriraj-dangi
Did you get the solution of this problem?
