09-08-2023 08:36 PM - edited 09-08-2023 08:38 PM
I am planning to upgrade my C93180YC-FX3 switch from version 9.3.8 to 10.3.3. but during the upgrade process I get the message "Return code 0x40450037 (Not a valid nxos image)".
I have confirmed that the nxos64-cs.10.3.3.F.bin file md5 is correct.
Attached below is the current show ver message:
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2021, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 01.08
NXOS: version 9.3(8)
BIOS compile time: 05/06/2022
NXOS image file is: bootflash:///nxos.9.3.8.bin
NXOS compile time: 8/4/2021 13:00:00 [08/05/2021 06:25:26]
Hardware
cisco Nexus9000 C93180YC-FX3 Chassis
Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 16336640 kB of memory.
Processor Board ID
Device name:N9K
bootflash: 115805708 kB
Kernel uptime is 0 day(s), 0 hour(s), 29 minute(s), 26 second(s)
Last reset at 598619 usecs after Sat Sep 9 10:41:50 2023
Reason: Module PowerCycled
System version:
Service: HW check by card-client
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
--More--
N9K# show install all impact nxos bootflash:nxos64-cs.10.3.3.F.bin
Installer will perform impact only check. Please wait.
Verifying image bootflash:/nxos64-cs.10.3.3.F.bin for boot variable "nxos".
[# ] 0%
[# ] 0% -- FAIL.
Return code 0x40450037 (Not a valid nxos image).
Solved! Go to Solution.
09-08-2023 08:51 PM
@id404 hi try upgrade in recommended path .
Recommended path: 9.3(8) → 10.2(4)M → 10.3(3)F
09-08-2023 08:51 PM
01-10-2024 09:39 AM
9.3.10 is the lowest nxos upgradeable to 10.x - if ISSU is not required:
Compatibility check is done:
Module bootable Impact Install-type Reason
1 yes disruptive reset Incompatible image for ISSU
Images will be upgraded according to following table:
Module Image Running-Version(pri:alt) New-Version Upg-Required
1 nxos 9.3(10) 10.4(2) yes
1 bios v05.47(04/28/2022):v05.45(07/05/2021) v05.51(11/29/2023) yes
