09-10-2022 07:08 PM
I would like to monitor the CPU load of NX-OS node and send an SNMP trap in case of CPU Threshold Rising and Falling
In order to trigger an event I assume we have to the syslog message/ID generated in case CPU Threshold Rising or Failing.
And then adding a desired action, such as send an SNMP Trap.
I began to write an EEM script, but got stuck. I would appreciate, if someone could please advise on:
syslog message/IDs for CPU threshold rising/falling
What snmp-trap ID has to be sent under action.
Thanks a lot.
Netmart
event manager applet RisingCPU
event syslog pattern "SYS-1-CPURISINGTHRESHOLD"
action 1.1 snmp-trap xxxxxx "CPU RISING Threshold"
intdata1 Enter integer data 1 to be included in the payload
intdata2 Enter integer data 2 to be included in the payload
strdata Enter the string data to be included in the payload
event manager applet FallingCPU
event syslog pattern "SYS-1-CPUFALLINGTHRESHOLD"
action 1.1 snmp-trap xxxxxx "CPU FALLING Threshold"
09-11-2022 12:02 PM - edited 09-11-2022 12:04 PM
Hi @Netmart
I suppose you can simply use "strdata" to write your message in the SNMP trap as "CPU RAISING/FALLING" or whatever is more informative for you.
In the end, you can update 2 integer and one string data objects, basically these OIDs:
So it's up to you and the NMS you use to know which one works better for you.
Take care,
Sergiu
09-11-2022 02:09 PM - edited 09-11-2022 02:23 PM
Thank you Sergiu.
So it would look like the EM applets suggested below?
And if so, we still have to enable the traps - which would be the appropriate one?
event manager applet RisingCPUthreshold
action 1.1 snmp-trap intdata1 1.3.6.1.4.1.9.10.134.1.2.3.1.2
action 1.2 snmp-trap strdata "CPU Rising Threshold"
event manager applet FallingCPUthreshold
action 1.1 snmp-trap intdata2 1.3.6.1.4.1.9.10.134.1.2.3.1.3
action 1.2 snmp-trap strdata "CPU Falling Threshold"
(config)#snmp-server enable traps ?
<CR>
aaa Enable aaa traps
bridge Enable bridge traps
callhome Enable callhome traps
cfs Enable cfs traps
config Enable config traps
entity Enable entity traps
feature-control Enable feature-control traps
generic Enable generic traps
license Enable license traps
link Enable link traps
rf Enable rf traps
rmon Enable rmon traps
snmp Enable snmp traps
storm-control Enable storm-control traps
stpx Enable stpx traps
sysmgr Enable sysmgr traps
system Enable system traps
upgrade Enable upgrade traps
vtp Enable vtp trap
