CISCO SWITCH Ver7.69
subimalsahoo
Switch G2
Device detected on 0:1:2 after 0 msecs
Device detected on 0:1:1 after 0 msecs
Device detected on 0:1:0 after 0 msecs
MCFrequency 1333Mhz
Relocated to memory
Time: 11/30/2024 8:31:41
Pre-Reserving Memory Bar of size 8000000 for root-port B0|D1C|F0 7ffffff 4
Detected CISCO IOFPGA
MIFPGA Present
Code Signing Results: 0x0
Using Golden FPGA
Checking and setting PSU fan directions
Booting from Primary Bios
FPGA Revison : 0x9
FPGA ID : 0x1528227
FPGA Date : 0x20161122
Power Debug Register: 0x0
Reset Cause Register: 0x80000000
Boot Ctrl Register : 0xe0ff
FPGA Update Status : 0x0
FPGA SPI Flash Micron(Numonyx) N25Q064A
Detected CISCO MIFPGA
FPGA Update Status : 0x20
Version 2.16.1240. Copyright (C) 2013 American Megatrends, Inc.
Board type 2
IOFPGA @ 0xc8000000
SLOT_ID @ 0xf
ERROR ERROR No bootflash. Rebooting
ERROR ERROR No bootflash. Rebooting in 60 secs
ERROR ERROR No bootflash. Rebooting in 50 secs
ERROR ERROR No bootflash. Rebooting in 40 secs
ERROR ERROR No bootflash. Rebooting in 30 secs
ERROR ERROR No bootflash. Rebooting in 20 secs
ERROR ERROR No bootflash. Rebooting in 10 secs
can any one know how to fix this or is this RMA
marce1000
 - It could be an RMA ; you may try a full power cycle and attach a console , look at the self tests during power up and check if the problem remains the same after a full power cycle.
   If you can get a 'loader >' prompt you may try  booting the Switch using an USB flash drive ; be aware that the USB flash drive must be formatted in FAT32 in order to be recognized by the Switch in the loader> prompt.
                                    Afterwards issue the command  dir bootflash:
  M.
marce1000
  M.
