delayed show command output with error code
Lukas Mazur
Frequent Visitor
Frequent Visitor
hi all,
i've got a weird behavior on one of mine ESX hosts.
when i execute a show command related to a specific module / interface the output takes some time and sometimes generates an error.
The ESX host is patched to the latest release and im running N1kv 1(2).
have a look at the commands:
a show mod indicates nothing suspicious:
N1kv# sh mod
Mod  Ports  Module-Type                      Model              Status
1    0      Virtual Supervisor Module        Nexus1000V         active *
2    0      Virtual Supervisor Module        Nexus1000V         ha-standby
3    248    Virtual Ethernet Module          NA                 ok
4    248    Virtual Ethernet Module          NA                 ok
5    248    Virtual Ethernet Module          NA                 ok
Mod  Sw               Hw
1    4.0(4)SV1(2)     0.0
2    4.0(4)SV1(2)     0.0
3    4.0(4)SV1(2)     1.11
4    4.0(4)SV1(2)     1.10
5    4.0(4)SV1(2)     1.11
Mod  MAC-Address(es)                         Serial-Num
1    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
2    00-19-07-6c-5a-a8 to 00-19-07-6c-62-a8  NA
3    02-00-0c-00-03-00 to 02-00-0c-00-03-80  NA
4    02-00-0c-00-04-00 to 02-00-0c-00-04-80  NA
5    02-00-0c-00-05-00 to 02-00-0c-00-05-80  NA
Mod  Server-IP        Server-UUID                           Server-Name
1    172.22.210.1     NA                                    NA
2    172.22.210.1     NA                                    NA
3    172.22.210.102   3f766178-0f44-11df-1111-aaaaaaaaa05f  vie-esx2.ucs.
4    172.22.210.103   3f766178-0f44-11df-1111-aaaaaaaaa02f  vie-esxi1.ucs.
5    172.22.210.104   3f766178-0f44-11df-1111-aaaaaaaaa03f  vie-esxi2.ucs.
when i take a look at the interfaces with show int x/x for the eth / po interfaces i get an error :
N1kv# sh int po 1
Error sending opc 9004 to sap 800 on node 0x302 for ifidx 16000000 (err=0x6e)
Unable to get sf stat for port channel port-channel1
port-channel1 is up
  Hardware: Port-Channel, address: 0050.565a.bb2f (bia 0050.565a.bb2f)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is trunk
  full-duplex, 10 Gb/s
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Switchport monitor is off
  Members in this channel: Eth3/2
  2 interface resets
or
N1kv# sh int eth 3/2
Error sending opc 9004 to sap 800 on node 0x302 for ifidx 1a020100 (err=0x6e)
Ethernet3/2 is up
  Hardware: Ethernet, address: 0050.565a.bb2f (bia 0050.565a.bb2f)
     reliability 0/255, txload 0/255, rxload 0/255
  Encapsulation ARPA
  Port mode is trunk
  Auto-Negotiation is turned off
  Auto-mdix is turned on
  1 interface resets
it takes some time till the output is displayed (app 10-15sek).
on the veth side i have the same delay but no error message is displayed.
thats my config of the uplink port-profile
port-profile type ethernet Uplink
  vmware port-group
  switchport mode trunk
  switchport trunk native vlan 210
  switchport trunk allowed vlan all
  channel-group auto mode on mac-pinning
  no shutdown
  system vlan 210-213,215-216
  state enabled
the ESX host is accessible and traffic also passes the VEM.
i had this issue some weeks ago but a simple reboot of the host did the job - since this is the second time I'll keep the host running.
maybe we can investigate together what might cause this behavior.
BR
Lukas
nenduri
Lukas,
Can you send the output of the following command on VSM?
show svs neighbors
thanks,
Naren
hi Naren,
i experienced the issue again ... ( 2 weeks everything was ok)
here's the output of sh svs neighbors
N1kv# sh svs neighbors
Active Domain ID: 1
AIPC Interface MAC: 0050-56ab-783b
Inband Interface MAC: 0050-56ab-2c62
Src MAC           Type   Domain-id    Node-id     Last learnt (Sec. ago)
0050-56ab-416c     VSM         1         0201     677183.33
0002-3d40-6502     VEM         1         0302     424038.86
0002-3d40-0105     VEM         1         0402     410030.50
0002-3d40-0104     VEM         1         0502     677143.50
0002-3d40-0105     VEM         1         0602     410030.50
thx lukas
Hi Lukas,
The issue is two modules (in your case it is module 6 and module 4) having the same MAC address. All the unicast messages to module 4 will fail.
This has been fixed and the fix will be available in the upcoming release. (April 2010).
Active Domain ID: 1
The work around is, on module 4 run the following commands:
vem stop
vem start
thanks,
Naren
