05-11-2011 05:00 AM
I am currently upgrading the virtualisation environment. vCenter and VSM is updated and it's all running fine.
For upgrading the VEM's and the ESX's I moved some VM's to another ESX and the VM's lost connection. I found that the problem ist that one of my ESX doesn't get every Vlan and every PortProfile which is very strange.
As you can see with the vemcmd show dr command I am missing vlan100 on my second ESX. On my TestCluster I could fix this with deleting the vlan and recreate it, but i don't want to do this in this highly productive environment. So did anybody see this issue as well or do i have to fix this on a weekend?
!Log from my first ESX
N1000v# mod vem 3 execute vemcmd show dr
BD 1, vdc 1, vlan 1, 9 ports, DR 0, multi_uplinks TRUE
Portlist:
16 vmnic0
18 vmnic2
19 vmnic3
20 vmnic4
21 vmnic5
22 vmnic6
304
305
306
BD 100, vdc 1, vlan 100, 5 ports, DR 305, multi_uplinks TRUE
Portlist:
20 vmnic4
21 vmnic5
58 ServerA.eth1
79 ServerB.eth1
305 DR
BD 106, vdc 1, vlan 106, 3 ports, DR 305, multi_uplinks TRUE
Portlist:
20 vmnic4
21 vmnic5
305 DR
BD 300, vdc 1, vlan 300, 8 ports, DR 305, multi_uplinks TRUE
Portlist:
20 vmnic4
21 vmnic5
51 ServerC.eth2
52 ServerD.eth1
305 DR
!Log from my second ESX
N1000v# mod vem 4 execute vemcmd show dr
Portlist:
16 vmnic0
18 vmnic2
19 vmnic3
20 vmnic4
21 vmnic5
22 vmnic6
304
305
306
BD 106, vdc 1, vlan 106, 3 ports, DR 306, multi_uplinks TRUE
Portlist:
20 vmnic4
21 vmnic5
306 DR
BD 300, vdc 1, vlan 300, 3 ports, DR 306, multi_uplinks TRUE
Portlist:
20 vmnic4
21 vmnic5
306 DR
05-17-2011 08:03 PM
Chris,
Version of 1000v?
Version of ESX (affected host)?
From affected host "vemcmd show trunk"
Can you also paste (or send me privately) your running config.
Robert
05-18-2011 12:36 AM
Hi Robert,
Thanks for your reply. By now the problem is fixed. After upgrading both VSM somehow the vlans were faulty. I figured this out with the comparison of "show vlan" and "show system internal l2fm info detail". The system command didn't show every vlan therefore, the VEM didn't get every vlan they needed.
After a reload of the VSM and not just a reload of module 1 and module 2 the system command knew every vlan and after a vem restart it worked fine again.
This happend during upgrading from version 4.0(4)SV1(2) to version 4.0(4)SV1(3b).
Chris
