ā04-03-2020 09:05 PM
hi guys
I want to disable mac learning on nexus 9500 with nx-os 9.3.3 but Unfortunately i didn`t found any thing about disable mac learning on nexus 9500 with nx-os 9.3.3
i found a command in nexus 3548 with nx-os 6.x
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3548/sw/layer_2_switching/60x/b_Cisco_N3548_Layer_2_Switching_Config_602_A1_1/b_Cisco_N3548_Layer_2_Switching_Config_602_A1_1_chapter_01001.html
but this command not found in nexus 3548 with nx-os 9.3.3
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus3000/sw/layer2/93x/configuration/guide/b-cisco-nexus-3000-nx-os-layer-2-configuration-guide-93x.html
How can I do this
ā04-04-2020 03:47 AM - edited ā04-04-2020 03:48 AM
I believe the command you are looking for:
N9K-1(config)# mac-learn disable disable Mac Learning disable to use switch as a HUB. Do a clear mac address-table dynamic after disabling mac learning
Sergiu
ā03-22-2022 09:21 PM
im using System version: 7.0(3)I7(7) in cisco Nexus9000 93180YC-EX
i tried that command but there is error coming: config not supported on platform
Please need help.
Jose
ā04-04-2020 04:32 AM
thank you for your replay but
switch(config)# mac-learn disable
ā04-04-2020 05:26 AM - edited ā04-04-2020 05:27 AM
I am a bit confused. Do you want to disable the mac learning on nexus 9500 or 3500?
If it's Nexus 3500, then the mac learning is disabled like this:
switch# configure terminal switch(config)# interface type slot/port switch(config-if)# [no] switchport mac-learn disable switch(config-if)# clear mac address-table dynamic interface type slot/port
Note1:The no form of switchport mac-learn disable command re-enables MAC address learning on Layer 2 interfaces.
Note2: After disabling MAC address learning on an interface, ensure that you clear the MAC address table.
For Nexus 9000 (9300/9500) I will check once again the documentation. It is possible that not all platforms to support disabling the mac learning.
Can you share the exact switch model you have (line card model if you have a nexus 9500)?
Sergiu
ā04-04-2020 06:21 AM
my switch is nexus 9500
switch(config-if)# switchport mac-learn disable
Config not supported on this Platform
if this platform not support to deactivate mac learnig , is there any soloution to use switch as hub
ā04-04-2020 08:55 AM
What line cards do you have on your N9500 and what version is it running on your switch?
ā04-04-2020 11:32 PM
i use N9K-X9736C-FX
ā04-05-2020 06:40 AM - edited ā04-05-2020 06:41 AM
I have searched for disabling mac learning on -FX based platforms, and I am not able to find any limitations about it. However, it seems that the command is restricted from hardware to avoid disabling the mac learning.
But my question is why would you want your switch to behave like a hub? Especially a Nexus 9500 switch? I am sure we can find a better solution for your requirements. :-)
Sergiu
ā04-06-2020 05:18 AM - edited ā04-06-2020 11:34 PM
@Sergiu.Daniluk wrote:Hi,
If it's Nexus 3500, then the mac learning is disabled like this: prepaidgiftbalance
switch# configure terminal switch(config)# interface type slot/port switch(config-if)# [no] switchport mac-learn disable switch(config-if)# clear mac address-table dynamic interface type slot/portNote1:The no form of switchport mac-learn disable command re-enables MAC address learning on Layer 2 interfaces.
Sergiu
hello sir is your problem solved?
ā04-07-2020 02:43 AM
no ,
ā04-07-2020 03:44 AM
Hi John,
I can confirm there is no official way to disable the mac learning on Nexus 9500/9300, -EX -FX generations.
What is the use case where you need mac learning disabled?
Sergiu
ā11-26-2021 09:59 AM
Hi Sergiu,
for us, this is very useful, because I would like to set MACs manually per port. Recently there is no way how you can "secure" the port in terms of collision/hijacking/flooding MAC addresses in that environment, where you have no control over endpoints connected to your infrastructure. Normally we would use "feature port-security", however, this is not supported with VxLAN/EVPN. This feature is not supported by vPC fabric-peering as well. Therefore we would like to configure static MAC+port association and disable dynamic learning. I understood this is not supported, because even with MAC ACL, dynamic learning will learn and propagate MAC over the control plane (EVPN).
ā02-02-2022 10:33 PM
Old thread, but FYI: if you configure static mac address, then for that specific mac address there will be no more dynamic learning. In other words, you can convert all your already dynamically learned MAC addresses to static, to avoid any collision/hijack etc.
Stay safe,
Sergiu
ā02-03-2022 12:26 AM
It is old but still actual. Thank you for your response. Unfortunately, even with static MAC config, Nexus 9300 will learn MACs in the control plane and it will redistribute all MACs (even unconfigured ones) over EVPN to other switches. Luckily enough, MAC address learning is possible to disable in NXOS 10.2(2) and later. I haven't tested it as of yet though.
N93180YC(config)# mac-learn ? disable Mac Learning disable to use switch as a HUB. Do a clear mac address-table dynamic after disabling mac learning N93180YC(config)# mac-learn disable <CR> N93180YC# sh mac address-table dynamic Legend: * - primary entry, G - Gateway MAC, (R) - Routed MAC, O - Overlay MAC age - seconds since last seen,+ - primary entry using vPC Peer-Link, (T) - True, (F) - False, C - ControlPlane MAC, ~ - vsan, (NA)- Not Applicable VLAN MAC Address Type age Secure NTFY Ports ---------+-----------------+--------+---------+------+----+------------------ N93180YC#
Have a nice day, Marian
