06-05-2024 12:07 AM
I have updated one Nexus 92348GC-X Switch to version 10.3.4a.
I was hoping I can use the "configuration dual-stage" mode after the upgrade.
But - when I type "configuration dual-stage" from execution mode, I getting this message -
"command supported in dual-stage mode" and the switch remains in execution mode.
Does Cisco limits this dual-stage mode only for certain models of Nexus switches only?
Or am I doing something wrong?
Solved! Go to Solution.
09-02-2024 03:51 AM
The dual-stage configuration depends on DME support. However, N9K-C92348GC-X does not support DME in version 10.3.4a. You can upgrade to either version 10.4(3) or 10.5(1), and it should be supported.
08-05-2024 12:04 PM
Per the NX-OS feature support matrix, two-stage is supported on the model in question in v. 10.1(2) and later, https://www.cisco.com/c/dam/en/us/td/docs/Website/datacenter/platform/platform.html.
Can you attach a screenshot?
Joe
09-02-2024 01:54 AM
Here comes the screenshot. The switch refuses to go to two-stage mode -
09-02-2024 03:51 AM
09-02-2024 08:57 AM
Many thanks for a quick resolution. I didn't know that dual-stage is based on dme and different model got dme in different version. Even Cisco product support matrix is not updated correctly. Now verified this works with ver 10.5.1.
09-10-2024 07:06 PM
Thank you for your feedback. I have collaborated with the doc team to include this limit in the configuration guide:
