Error in Nexus 9K : port not compatible:[Members in multiple FEX]
I am trying to configure the Port-channel with each members in 2 different FEX 151  & 152  , But I am getting below error while adding the 2 interface to port-channel, here the error.
M02@rt37
Hello @Orlando Chaparro,
Do you always have this issue?
Do you test to delete the physical interfaces' configuration and configure only the command channel-group 213 mode active.
You have just to configure first the Po and apply the channel-group command on the physical interfaces. They are automaticly configured.
Best regards
