This is internal error message from ACL susbsystem (Internal ACL Database got into some inconsistent State). When are you hitting this problem, is it during addition/deletion of the acl.
Could you dump the running configuration, and provide interface/port-profile, on which you are configuring ACL.
Also could you provide the information on any ACL releated configuration, prior to this.
srini.
