06-16-2016 08:15 AM
Hi everyone,
Could someone help me with the problem below? I wanted to add new VLANs 60 & 61 but they are suspended/disallowed over the Peer Link or the Trunk, Does anyone of you have experience in this issue please help?
7K4(config)# show vpc consistency-parameters global
Name Type Local Value Peer Value
STP Mode 1 Rapid-PVST Rapid-PVST
STP Disabled 1 None None
STP MST Region Name 1 "" ""
STP MST Region Revision 1 0 0
STP MST Region Instance to 1
VLAN Mapping
STP Loopguard 1 Enabled Enabled
STP Bridge Assurance 1 Enabled Enabled
STP Port Type, Edge 1 Normal, Disabled, Normal, Disabled,
BPDUFilter, Edge BPDUGuard Enabled Enabled
STP MST Simulate PVST 1 Enabled Enabled
Interface-vlan admin up 2 20,80,211,280,283,901- 20,80,211,280,283,901-
903 903
Interface-vlan routing 2 20,70,80,211,280,283,9 20,70,80,211,280,283,9
capability 01-903 01-903
Allowed VLANs - 10-13,20,24,60-61,70,8 10-13,20,24,70,80,156,
0,156,211,278,280-286, 211,278,280-286,901-90
901-903,3000 3,3000
Local suspended VLANs - 60-61
#Show logging
2016 Jun 16 08:02:35 7K4 %ETHPORT-3-IF_ERROR_VLANS_SUSPENDED: VLANs 60-61
on Interface port-channel3012 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
on Interface port-channel3011 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
on Interface port-channel3010 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
on Interface port-channel1101 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
on Interface port-channel1051 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
on Interface port-channel1050 are being suspended. (Reason: Vlan is not allowed
on Peer-link)
#show interface trunk
Port Vlans Err-disabled on Trunk
Eth4/2 60-61
Eth4/4 60-61
Eth4/6 60-61
Eth4/8 60-61
Po1000 60-61
Po1050 60-61
Po1051 60-61
Po1101 60-61
Po3010 60-61
Po3011 60-61
Po3012 60-61
Eth101/1/30 60-61
Eth101/1/43 60-61
Eth101/1/44 60-61
Eth101/1/45 60-61
Eth101/1/46 60-61
Eth101/1/47 60-61
Eth101/1/48 60-61
06-19-2016 12:16 PM
Hi there,
Vlans 60-61 are suspended because they are only allowed on the peer-link end of the local switch, but they weren't allowed on the peer switch also - so they're suspended due to vPC config inconsistency. Take another look at the "show vpc consistency-parameters global" output you have provided and you will notice that:
Allowed VLANs
Local Value:
10-13,20,24,60-61,70,80,156,211,278,280-286,901-903,3000
Peer Value:
10-13,20,24,70,80,156, 211,278,280-286,901-903,3000
After fixing the allowed vlans mismatch, you'll see them removed from the suspended vlans list; if you don't - pls share the vPC related running config.
Cheers!
