FCoE and NFS running over the same uplinks?
kevin.tunge.xcel
Beginner
Beginner
Hello Experts,
I'm trying to figure out how we can run FCoE and NFS all from the same Netapp, down through a pair of 5k's, and then to our FI's over the same uplinks. I myself do not have visibility to the 5K's, which is where I understand most of the config needs to happen.
Currently, the uplinks are exclusively used for FCoE. We also want NFS to run through the same uplinks.
From what I have read/gathered, is that we should really just need to bind the NFS VLAN to the already-existing VSAN. Just looking for confirmation on whether or not this should be possible/supported, and if I'm tracking correctly. Any help is greatly appreciated!
mallen
Enthusiast
Enthusiast
Kevin,
What you are trying to do is accomplished by adding another VLAN to the design to carry the NFS/Ethernet traffic. What you will end up is one VLAN for FCoE (which is mapped to a VSAN for Fibre Channel Services) and another VLAN for your NFS traffic (or any other Ethernet traffic you want). There is a paper available on cisco.com that goes through this for NetApp environments (FlexPod and FCoE with VPC and NetApp Storage Configuration Example - Cisco).
Mark
Recognize Your Peers
