For my understanding (system-uplink, data-uplink)
thorstenn
Level 4
Level 4
on the nexus i have the port-profiles "system-uplink" and "data-uplink".
The "system-uplink" is only for traffic between the VSM and the VEM and needs only one NIC connection (better two for HA, right?)
The "data-uplink" is for traffic between the nexus and the VMs, right?
I have eight ports on the ESX hosts. What is a good setup?
2x system-uplink
4x data-uplink
2x vmotion
For the "4x data-uplink" it is useful to create a etherchannel on the nexus and the physical switch?
Thanks and regards
Thorsten
Robert Burns
An uplink is any phsyical connection between an ESX VEM host and an upstream switch.
System Uplink - Carries system VLANs - control and Packet
Data/VM Uplink - Carries the VM data traffic
If you want a dedicated one for VMotion thats fine also.  You can dedicate a NIC to VMotion just like you would in a non-DVS set.
Please see below for more info.  There are suggested configuration examples that will help you design your setup.
http://cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_0/interface/configuration/guide/n1000v_interface.html
Regards.
Robert
