07-23-2019 04:03 AM - edited 07-23-2019 04:04 AM
I've got a DC topology where i get ingress traffic from 3x10GB lagged interface which are egress to FEX port (2x10gb). And on that 2x10GB ports i got lots of output discards counting ON. I got no specified queening configured, but the couter of dropped bytes is scary.
show queuing interface ethernet 1/23
| Tx Pkts | 6489633480490| 395439| 11794585|
| Tx Byts |8481580517561871| 600980859| 2133802229|
| Dropped Pkts | 7303751537| 0| 0|
| Dropped Byts | 10498912379407| 0| 0|
| Q Depth Byts | 32240| 0| 0|
Is there anything you could recommend ? Create a qos with buffers ? Etc ? I dont know why it's happening since the ingress and egress interfaces is the same capacity (10gb)
Device: cisco Nexus9000 C9372PX
Thank you for any input.
07-23-2019 11:39 PM
Hi @from88 ,
Can you paste the full output of command show queuing interface ethernet 1/23?
Also show interface e1/23, show hardware rate-limit module 1 and show policy-map interface control-plane.
Remi Astruc
07-24-2019 12:17 AM
hello,
Here you are:
show interface e1/23 Ethernet1/23 is up admin state is up, Dedicated Interface Belongs to Po25 Hardware: 1000/10000 Ethernet, address: 0062.ec1a.191c (bia 0062.ec1a.191c) Description: ITXFEX125 MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec reliability 255/255, txload 32/255, rxload 39/255 Encapsulation ARPA, medium is broadcast Port mode is fex-fabric full-duplex, 10 Gb/s, media type is 10G Beacon is turned off Auto-Negotiation is turned on, FEC mode is Auto Input flow-control is off, output flow-control is off Auto-mdix is turned off Rate mode is dedicated Switchport monitor is off EtherType is 0x8100 EEE (efficient-ethernet) : n/a Last link flapped 71week(s) 0day(s) Last clearing of "show interface" counters 20:37:01 0 interface resets 30 seconds input rate 1560567800 bits/sec, 150573 packets/sec 30 seconds output rate 1273727960 bits/sec, 125790 packets/sec Load-Interval #2: 5 minute (300 seconds) input rate 2.60 Gbps, 229.60 Kpps; output rate 2.17 Gbps, 193.72 Kpps RX 16215032495 unicast packets 24218 multicast packets 0 broadcast packets 16215056713 input packets 20952139531262 bytes 13275675582 jumbo packets 0 storm suppression packets 0 runts 0 giants 0 CRC 0 no buffer 0 input error 0 short frame 0 overrun 0 underrun 0 ignored 0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop 0 input with dribble 0 input discard 0 Rx pause TX 15306294432 unicast packets 768894 multicast packets 2584 broadcast packets 15307065910 output packets 20140093661160 bytes 12780926079 jumbo packets 0 output error 0 collision 0 deferred 0 late collision 0 lost carrier 0 no carrier 0 babble 3360277 output discard 0 Tx pause show hardware rate-limit module 1 Units for Config: packets per second Allowed, Dropped & Total: aggregated since last clear counters Module: 1 R-L Class Config Allowed Dropped Total +------------------+--------+---------------+---------------+-----------------+ L3 glean 100 183852281 24073009 207925290 L3 mcast loc-grp 3000 0 0 0 access-list-log 100 0 0 0 bfd 10000 0 0 0 exception 50 0 0 0 fex 3000 1055027064 0 1055027064 span 50 0 0 0 dpss 6400 0 0 0 sflow 40000 0 0 0 show policy-map interface control-plane Control Plane Service-policy input: copp-system-p-policy-strict class-map copp-system-p-class-l3uc-data (match-any) match exception glean set cos 1 police cir 250 pps , bc 32 packets module 1 : transmitted 765315655 packets; dropped 6366861 packets; class-map copp-system-p-class-critical (match-any) match access-group name copp-system-p-acl-bgp match access-group name copp-system-p-acl-rip match access-group name copp-system-p-acl-vpc match access-group name copp-system-p-acl-bgp6 match access-group name copp-system-p-acl-ospf match access-group name copp-system-p-acl-rip6 match access-group name copp-system-p-acl-eigrp match access-group name copp-system-p-acl-ospf6 match access-group name copp-system-p-acl-eigrp6 match access-group name copp-system-p-acl-auto-rp match access-group name copp-system-p-acl-mac-l3-isis set cos 7 police cir 19000 pps , bc 128 packets module 1 : transmitted 42048305 packets; dropped 0 packets; class-map copp-system-p-class-important (match-any) match access-group name copp-system-p-acl-hsrp match access-group name copp-system-p-acl-vrrp match access-group name copp-system-p-acl-hsrp6 match access-group name copp-system-p-acl-vrrp6 match access-group name copp-system-p-acl-mac-lldp set cos 6 police cir 3000 pps , bc 128 packets module 1 : transmitted 229270471 packets; dropped 0 packets; class-map copp-system-p-class-openflow (match-any) match access-group name copp-system-p-acl-openflow set cos 5 police cir 2000 pps , bc 32 packets module 1 : transmitted 118 packets; dropped 0 packets; class-map copp-system-p-class-multicast-router (match-any) match access-group name copp-system-p-acl-pim match access-group name copp-system-p-acl-msdp match access-group name copp-system-p-acl-pim6 match access-group name copp-system-p-acl-pim-reg match access-group name copp-system-p-acl-pim6-reg match access-group name copp-system-p-acl-pim-mdt-join set cos 6 police cir 3000 pps , bc 128 packets module 1 : transmitted 12 packets; dropped 0 packets; class-map copp-system-p-class-multicast-host (match-any) match access-group name copp-system-p-acl-mld set cos 1 police cir 2000 pps , bc 128 packets module 1 : transmitted 911634 packets; dropped 0 packets; class-map copp-system-p-class-l3mc-data (match-any) match exception multicast rpf-failure match exception multicast dest-miss set cos 1 police cir 3000 pps , bc 32 packets module 1 : transmitted 0 packets; dropped 0 packets; class-map copp-system-p-class-normal (match-any) match access-group name copp-system-p-acl-mac-dot1x match protocol arp set cos 1 police cir 1500 pps , bc 32 packets module 1 : transmitted 2783172463 packets; dropped 96739 packets; class-map copp-system-p-class-ndp (match-any) match access-group name copp-system-p-acl-ndp set cos 6 police cir 1500 pps , bc 32 packets module 1 : transmitted 563115 packets; dropped 0 packets; class-map copp-system-p-class-normal-dhcp (match-any) match access-group name copp-system-p-acl-dhcp match access-group name copp-system-p-acl-dhcp6 set cos 1 police cir 300 pps , bc 32 packets module 1 : transmitted 22739 packets; dropped 0 packets; class-map copp-system-p-class-normal-dhcp-relay-response (match-any) match access-group name copp-system-p-acl-dhcp-relay-response match access-group name copp-system-p-acl-dhcp6-relay-response set cos 1 police cir 400 pps , bc 64 packets module 1 : transmitted 115514 packets; dropped 0 packets; class-map copp-system-p-class-normal-igmp (match-any) match access-group name copp-system-p-acl-igmp set cos 3 police cir 6000 pps , bc 64 packets module 1 : transmitted 220416 packets; dropped 0 packets; class-map copp-system-p-class-redirect (match-any) match access-group name copp-system-p-acl-ptp set cos 1 police cir 1500 pps , bc 32 packets module 1 : transmitted 0 packets; dropped 0 packets; class-map copp-system-p-class-exception (match-any) match exception ip option match exception ip icmp unreachable match exception ipv6 option match exception ipv6 icmp unreachable set cos 1 police cir 50 pps , bc 32 packets module 1 : transmitted 68 packets; dropped 21 packets; class-map copp-system-p-class-exception-diag (match-any) match exception ttl-failure match exception mtu-failure set cos 1 police cir 50 pps , bc 32 packets module 1 : transmitted 4009922 packets; dropped 53 packets; class-map copp-system-p-class-management (match-any) match access-group name copp-system-p-acl-ftp match access-group name copp-system-p-acl-ntp match access-group name copp-system-p-acl-ssh match access-group name copp-system-p-acl-http match access-group name copp-system-p-acl-ntp6 match access-group name copp-system-p-acl-sftp match access-group name copp-system-p-acl-snmp match access-group name copp-system-p-acl-ssh6 match access-group name copp-system-p-acl-tftp match access-group name copp-system-p-acl-https match access-group name copp-system-p-acl-snmp6 match access-group name copp-system-p-acl-tftp6 match access-group name copp-system-p-acl-radius match access-group name copp-system-p-acl-tacacs match access-group name copp-system-p-acl-telnet match access-group name copp-system-p-acl-radius6 match access-group name copp-system-p-acl-tacacs6 match access-group name copp-system-p-acl-telnet6 set cos 2 police cir 3000 pps , bc 32 packets module 1 : transmitted 655292718 packets; dropped 0 packets; class-map copp-system-p-class-monitoring (match-any) match access-group name copp-system-p-acl-icmp match access-group name copp-system-p-acl-icmp6 match access-group name copp-system-p-acl-traceroute set cos 1 police cir 300 pps , bc 128 packets module 1 : transmitted 101610314 packets; dropped 0 packets; class-map copp-system-p-class-l2-unpoliced (match-any) match access-group name copp-system-p-acl-mac-stp match access-group name copp-system-p-acl-mac-lacp match access-group name copp-system-p-acl-mac-cfsoe match access-group name copp-system-p-acl-mac-sdp-srp match access-group name copp-system-p-acl-mac-l2-tunnel match access-group name copp-system-p-acl-mac-cdp-udld-vtp set cos 7 police cir 20000 pps , bc 8192 packets module 1 : transmitted 2472044401 packets; dropped 0 packets; class-map copp-system-p-class-undesirable (match-any) match access-group name copp-system-p-acl-undesirable match exception multicast sg-rpf-failure set cos 0 police cir 15 pps , bc 32 packets module 1 : transmitted 2485 packets; dropped 0 packets; class-map copp-system-p-class-fcoe (match-any) match access-group name copp-system-p-acl-mac-fcoe set cos 6 police cir 1500 pps , bc 128 packets module 1 : transmitted 0 packets; dropped 0 packets; class-map copp-system-p-class-nat-flow (match-any) match exception nat-flow set cos 7 police cir 100 pps , bc 64 packets module 1 : transmitted 0 packets; dropped 0 packets; class-map copp-system-p-class-l2-default (match-any) match access-group name copp-system-p-acl-mac-undesirable set cos 0 police cir 50 pps , bc 32 packets module 1 : transmitted 30397883 packets; dropped 6425137 packets; class-map class-default (match-any) set cos 0 police cir 50 pps , bc 32 packets module 1 : transmitted 22048545 packets; dropped 1885728 packets;
do you see something suspicious ?
Thank you
07-24-2019 01:39 AM
You missed also to paste the full output of command show queuing interface ethernet 1/23
Remi Astruc
07-24-2019 03:55 AM - edited 07-24-2019 04:03 AM
sorry, this is the output:
show queuing interface ethernet 1/23 slot 1 ======= Egress Queuing for Ethernet1/23 [System] ------------------------------------------------------------------------------ QoS-Group# Bandwidth% PrioLevel Shape QLimit Min Max Units ------------------------------------------------------------------------------ 3 - 1 - - - 6(D) 2 0 - - - - 6(D) 1 0 - - - - 6(D) 0 100 - - - - 6(D) +-------------------------------------------------------------------+ | QOS GROUP 0 | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 9528613680752| 641844| 202350| | Tx Byts |12613165589837630| 932469022| 69962346| | Dropped Pkts | 3108032358| 0| 782| | Dropped Byts | 4522891928871| 0| 1184204| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ | QOS GROUP 1 | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 0| 0| 0| | Tx Byts | 0| 0| 0| | Dropped Pkts | 0| 0| 0| | Dropped Byts | 0| 0| 0| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ | QOS GROUP 2 | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 0| 0| 0| | Tx Byts | 0| 0| 0| | Dropped Pkts | 0| 0| 0| | Dropped Byts | 0| 0| 0| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ | QOS GROUP 3 | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 0| 0| 0| | Tx Byts | 0| 0| 0| | Dropped Pkts | 0| 0| 0| | Dropped Byts | 0| 0| 0| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ | CONTROL QOS GROUP | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 14880291| 0| 358993147| | Tx Byts | 9107829873| 0| 26578915538| | Dropped Pkts | 1| 0| 0| | Dropped Byts | 642| 0| 0| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ | SPAN QOS GROUP | +-------------------------------------------------------------------+ | | Unicast | OOBFC Unicast | Multicast | +-------------------------------------------------------------------+ | Tx Pkts | 0| 0| 0| | Tx Byts | 0| 0| 0| | Dropped Pkts | 0| 0| 0| | Dropped Byts | 0| 0| 0| | Q Depth Byts | 0| 0| 0| +-------------------------------------------------------------------+ Port Egress Statistics -------------------------------------------------------- WRED Drop Pkts 0 EOQ(qos-group-0) Drop Pkts 0 Ingress Queuing for Ethernet1/23 ------------------------------------------------------------------ QoS-Group# Pause QLimit Buff Size Pause Th Resume Th ------------------------------------------------------------------ 3 - - - 10(D) 2 - - - 10(D) 1 - - - 10(D) 0 - - - 10(D) Port Ingress Statistics -------------------------------------------------------- Ingress MMU Drop Pkts 0 Ingress MMU Drop Bytes 0 PFC Statistics ---------------------------------------------------------------------------- TxPPP: 0, RxPPP: 0 ---------------------------------------------------------------------------- COS QOS Group PG TxPause TxCount RxPause RxCount 0 - - Inactive 0 Inactive 0 1 - - Inactive 0 Inactive 0 2 - - Inactive 0 Inactive 0 3 - - Inactive 0 Inactive 0 4 - - Inactive 0 Inactive 0 5 - - Inactive 0 Inactive 0 6 - - Inactive 0 Inactive 0 7 - - Inactive 0 Inactive 0 ----------------------------------------------------------------------------
Btw "Q Depth Byts" sometimes changes to 1040. Seems like this entry is dynamic one.
07-24-2019 06:49 AM - edited 07-24-2019 06:52 AM
The port supports a lot of traffic, and probably some bursty applications.
Although your input ports are also 10G, you can have output issues when several input ports egress the same port.
You should identify your bursty application and mitigate them. Also you can upgrade the port to a higher speed, or add ports in a Port-channel.
You can also try to change the Burst Profile with hardware qos ns-buffer-profile ultra-burst.
Finally if that cannot be enhanced, you will need to implement QoS to segregate some traffic explicitly.
Anyway it is worth opening a TAC case for deeper tshooting.
Remi Astruc
07-30-2019 06:47 AM
thank you, so much.
I want to try this: hardware qos ns-buffer-profile ultra-burst.
Maybe you know, is there are any disruption entering this command ? Do this require any reboot ,etc ?
Thank you
07-30-2019 09:46 AM
I don't really know.
I suggest you plan your maintenance window like if you would need a reboot after entering the command, just in case.
Remi Astruc
07-31-2019 12:49 AM
Thanks again,
Strange thing is that these discards mainly occurs on N9K-C9372-PX-E devices. We also have - N5K-C5548UP, N5K-C5672UP and on them there are no dicards. Could it be that N5K-C5548UP, N5K-C5672UP has bigger buffers than N9Ks ?
08-03-2019 04:56 AM
and maybe you can say - how to check the buffer interface has allocated ? to see if hardware burst profile ultra-burst helps.
Thank you!
