Hello! My first post.
Yes, everything seems to be working, but I have a few questions:
I have:
2 NXOS 3172PQ (7.0 (3) I7 (8)) and
1 WS-C3750E-48TD-E (universalk9-mz.152-4.E10) VPC member
- When I finished the settings, the SVI at CORE2_48 were not UP in L2 (protocol-down / link-down / admin-up).
- When I finished the settings, the SVI at CORE1_47 was UP in L2 (protocol-up / link-up / admin-up).
- In order to raise layer 2 at 48, I had to configure a interface as TRUNK, but I don't want to make it permanent. Named it EMERGENCY_PORT.
- We are migrating the network on VLAN1 to other SVI, but everything is on VLAN1
- How do I make changes to the VPC? If try to change will lose connection? Secondary shutdown the SVI, VPC ports and ORFHAN ports?
- Do I need DG on the managment port? at the moment it is configured with DG, I believe to be wrong.
I'm going to post some important settings and I can send more details.
I really tried, I read in many places, but it seems that some things are incorrect ...
Thank you so much!!!!
