10-23-2019 02:29 PM
How to validate part number to see if it is falling into END of Sale as per below following link
Product part numbers
Table 2. Product part numbers affected by this announcement
End-of-Sale Product Part Number | Product Description | Replacement Product Part Number | Replacement Product Description | Additional Information |
NXOS-703F3.3 | Nexus 9500/3600 Base NX-OS Software Rel 7.0(3)F3(3) | NXOS-9.2.4 | Nexus 9500, 9300, 3000 Base NX-OS Software Rel 9.2.4 | - |
NXOS-703F3.3= | Nexus 9500/3600 Base NX-OS Software Rel 7.0(3)F3(3) | NXOS-9.2.4 | Nexus 9500, 9300, 3000 Base NX-OS Software Rel 9.2.4 | - |
NXOS-703F3.4 | Nexus 9500/3600 Base NX-OS Software Rel 7.0(3)F3(4) | NXOS-9.2.4 | Nexus 9500, 9300, 3000 Base NX-OS Software Rel 9.2.4 | - |
NXOS-703F3.4= | Nexus 9500/3600 Base NX-OS Software Rel 7.0(3)F3(4) | NXOS-9.2.4 | Nexus 9500, 9300, 3000 Base NX-OS Software Rel 9.2.4 | - |
NXOS-703F3.5 | Nexus 9500/3600 Base NX-OS Software Rel 7.0(3)F3(5) | NXOS-9.2.4 | Nexus 9500, 9300, 3000 Base NX-OS Software Rel 9.2.4 | - |
sh hardware output
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2019, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php
http://opensource.org/licenses/gpl-3.0.html
http://www.opensource.org/licenses/lgpl-2.1.php
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 05.33
NXOS: version 9.2(3)
BIOS compile time: 09/08/2018
NXOS image file is: bootflash:///nxos.9.2.3.bin
NXOS compile time: 2/17/2019 5:00:00 [02/17/2019 11:07:27]
Hardware
cisco Nexus9000 C93180YC-FX Chassis
Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 65808588 kB of memory.
Processor Board ID XXXX
Device name: NNNN
bootflash: 115805356 kB
Kernel uptime is 91 day(s), 23 hour(s), 53 minute(s), 41 second(s)
Last reset at 715060 usecs after 1563917217
Reason: Module PowerCycled
System version:
Service: HW check by card-client
plugin
Core Plugin, Ethernet Plugin
Switch hardware ID information
Solved! Go to Solution.
10-23-2019 03:13 PM - edited 10-23-2019 03:13 PM
Hello Subrun,
That EOS notice is simply stating that you'll no longer be able to order N9K/N3Ks hardware pre-installed with NX-OS software version 7.0(3)F3(3-5).
There are no hardware components going EOS/EOL with this notice.
Additionally, you're running NX-OS 9.2(3) which is a relatively up to date release of NX-OS.
-Dustin
Hello Subrun,
-Dustin
