06-20-2020 06:12 PM
I'm having two Nexus 93108tc in Layer2 switch. two Nexus 93108 connect to 4503 by vPC,Today I have a problem where a 40Gbps(change to 1Gbps) port (1/36) is falling out of nowhere. It gets down and only returns when we remove the gbic cisco and put it back. We already changed the Gbic and the problem continues.
What can it be? Below the log:
2020 Jun 18 17:34:18 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel2: first operational port changed from Ethernet1/49 to none
2020 Jun 18 17:34:18 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel2: Ethernet1/49 is down
2020 Jun 18 17:34:18 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel2 is down (No operational members)
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel2,bandwidth changed to 100000 Kbit
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/49 is down (Link failure)
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel2 is down (No operational members)
2020 Jun 18 17:34:19 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/49, operational speed changed to 1 Gbps
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/49, operational duplex mode changed to Full
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/49, operational Receive Flow Control state changed to off
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/49, operational Transmit Flow Control state changed to off
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-channel2, operational speed changed to 1 Gbps
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-channel2, operational duplex mode changed to Full
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel2, operational Receive Flow Control state changed to off
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel2, operational Transmit Flow Control state changed to off
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel2: Ethernet1/49 is up
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel2: first operational port changed from none to Ethernet1/49
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel2,bandwidth changed to 1000000 Kbit
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/49 is up in mode trunk
2020 Jun 18 17:34:19 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-channel2 is up in mode trunk
2020 Jun 19 06:08:38 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel2: first operational port changed from Ethernet1/49 to none
2020 Jun 19 06:08:38 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_DOWN: port-channel2: Ethernet1/49 is down
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_PORT_CHANNEL_MEMBERS_DOWN: Interface port-channel2 is down (No operational members)
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel2,bandwidth changed to 100000 Kbit
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DOWN_LINK_FAILURE: Interface Ethernet1/49 is down (Link failure)
2020 Jun 19 06:08:39 zhongxinjifang9300-1 last message repeated 1 time
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface Ethernet1/49, operational speed changed to 1 Gbps
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface Ethernet1/49, operational duplex mode changed to Full
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface Ethernet1/49, operational Receive Flow Control state changed to off
2020 Jun 19 06:08:39 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface Ethernet1/49, operational Transmit Flow Control state changed to off
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-SPEED: Interface port-channel2, operational speed changed to 1 Gbps
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_DUPLEX: Interface port-channel2, operational duplex mode changed to Full
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_RX_FLOW_CONTROL: Interface port-channel2, operational Receive Flow Control state changed to off
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_TX_FLOW_CONTROL: Interface port-channel2, operational Transmit Flow Control state changed to off
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-PORT_UP: port-channel2: Ethernet1/49 is up
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETH_PORT_CHANNEL-5-FOP_CHANGED: port-channel2: first operational port changed from none to Ethernet1/49
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_BANDWIDTH_CHANGE: Interface port-channel2,bandwidth changed to 1000000 Kbit
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface Ethernet1/49 is up in mode trunk
2020 Jun 19 06:08:40 zhongxinjifang9300-1 %ETHPORT-5-IF_UP: Interface port-channel2 is up in mode trunk
2020 Jun 19 07:03:50 zhongxinjifang9300-1 %TAHUSD-SLOT1-4-BUFFER_THRESHOLD_EXCEEDED: Module 1 Instance 0 Pool-group buffer 90 percent threshold is exceeded!
