Jumbo frames on Nexus5548
MoulaAli480
We moved the NAS devices to the N5K switches, but now we are watching a lot of jumbo packets.
These NAS device is connected to our switches through 2 ports, one of each switch, grouped in a port-channel with VPC:
(example from one switch)
                bltpro7
                interface Ethernet1/25
                  description MONIT_NO VPC60 NAB250 HNAS
                  switchport mode trunk
                  spanning-tree port type edge trunk
                  no snmp trap link-status
                  channel-group 60 mode active
                interface port-channel60
                  speed 10000
                  vpc 60
If we check the interface details, we can see that the MTU is configured at 1500, but we are sending/receiving Jumbo packets
                bltpro7# show interface Po60
                port-channel60 is up
                vPC Status: Up, vPC number: 60
                  Hardware: Port-Channel, address: 00de.fb8d.9a00 (bia 00de.fb8d.9a00)
                  Description: MONIT_NO VPC60 NAB250 HNAS
                  MTU 1500 bytes,  BW 10000000 Kbit, DLY 10 usec
                  Encapsulation ARPA, medium is broadcast
                  Port mode is trunk
                  full-duplex, 10 Gb/s
                  Input flow-control is off, output flow-control is off
                  Switchport monitor is off
                  EtherType is 0x8100
                  Members in this channel: Eth1/25
                  Last clearing of "show interface" counters 3d11h
                  0 interface resets
                  30 seconds input rate 46185608 bits/sec, 7034 packets/sec
                  30 seconds output rate 53419344 bits/sec, 20476 packets/sec
                  Load-Interval #2: 5 minute (300 seconds)
                               input rate 43.24 Mbps, 6.83 Kpps; output rate 56.23 Mbps, 22.36 Kpps
                  RX
                               1872937387 unicast packets  9972 multicast packets  124 broadcast packets
                               1872947483 input packets  2493451346584 bytes
                               1602398068 jumbo packets  0 storm suppression bytes
                               0 runts  0 giants  0 CRC  0 no buffer
                               0 input error  0 short frame  0 overrun   0 underrun  0 ignored
                               0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
                               0 input with dribble  39853 input discard
                               0 Rx pause
                  TX
                               2685167916 unicast packets  15900800 multicast packets  228766254 broadcast packets
                               2929835221 output packets  571449328718 bytes
                               217270636 jumbo packets
                               0 output error  0 collision  0 deferred  0 late collision
                               0 lost carrier  0 no carrier  0 babble 0 output discard
                               0 Tx pause
This Jumbo packets are incremental:
                bltpro7# show interface Po60 | i jumbo
                               1605236730 jumbo packets  0 storm suppression bytes
                               219580151 jumbo packets
At policy level, we have these configuration applied:
                policy-map type network-qos jumbo
                  class type network-qos class-fcoe
                               pause no-drop
                               mtu 2158
                  class type network-qos class-default
                               mtu 9100
                system qos
                  service-policy type network-qos jumbo
                  service-policy type queuing input fcoe-default-in-policy
                  service-policy type queuing output fcoe-default-out-policy
                  service-policy type qos input fcoe-default-in-policy
Which MTU is applied to the interface? the class-default policy? or the 1500 of the interface?
Please help me with to clear jumbo frames.
Moula Ali
Sergiu.Daniluk
What is the output of:
show queuing interface ethernet X/Y
Sergiu
Ray D
"Which MTU is applied to the interface? the class-default policy? or the 1500 of the interface? "
For the configuration you have given the layer 2 MTU is set at 9100,
show interface Po60 is showing you the layer 3 MTU of the interface(1500), (on an SVI or routed link for example).
show queuing as outlined by Sergiu is showing you the layer 2 MTU of the interface - which is what is set in your case. It should be 9100 on the layer 2 queuing output.
Ray.
