05-19-2024 02:33 AM
Just like the title, I'm trying to configure it in gns3... but the l2tp tunnel won't active or up, also after exit the xconnect it shows an error below both in router 1 and router3
R3(config-if)# xconnect 10.0.0.1 13 encapsulation l2tpv3 pw-class r3
R3(config-if-xconn)#exit
Xconnect configuration on this circuit is incomplete
R3(config-if)#
here my sh run for both router 1 and router 3
---> Router 1:
R1#sh run
Building configuration...
Current configuration : 1959 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
ip tcp synwait-time 5
pseudowire-class r1
ip local interface Tunnel0
crypto isakmp policy 1
encr aes
authentication pre-share
group 5
lifetime 3600
crypto isakmp key secret address 3.3.3.3
crypto ipsec transform-set TRANS esp-aes 256 esp-sha-hmac
mode tunnel
crypto ipsec profile IPSEC
set transform-set TRANS
interface Loopback1
ip address 1.1.1.1 255.255.255.0
interface Tunnel0
ip address 10.0.0.1 255.255.255.0
tunnel source Loopback1
tunnel destination 3.3.3.3
tunnel protection ipsec profile IPSEC
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
ip address 192.168.10.1 255.255.255.0
media-type gbic
speed 1000
duplex full
negotiation auto
interface GigabitEthernet1/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet2/0
ip address 10.10.10.1 255.255.255.0
negotiation auto
xconnect 10.0.0.2 13 encapsulation l2tpv3 pw-class r1
! Incomplete or Invalid Xconnect config
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
interface FastEthernet4/0
no ip address
shutdown
speed auto
duplex auto
interface FastEthernet4/1
no ip address
shutdown
speed auto
duplex auto
router eigrp 100
network 1.0.0.0
network 10.0.0.0
network 192.168.0.0
network 192.168.10.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
---> Router3:
R3#sh run
Current configuration : 1981 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
pseudowire-class r3
encr aes
group 5
lifetime 3600
crypto isakmp key secret address 1.1.1.1
mode tunnel
interface Loopback1
ip address 3.3.3.3 255.255.255.0
interface Tunnel0
ip address 10.0.0.2 255.255.255.0
tunnel destination 1.1.1.1
no ip address
shutdown
duplex auto
no ip address
shutdown
media-type gbic
speed 1000
duplex full
negotiation auto
ip address 192.168.20.2 255.255.255.0
negotiation auto
ip address 10.10.13.1 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
speed auto
duplex auto
no ip address
shutdown
speed auto
duplex auto
router eigrp 100
network 3.0.0.0
network 10.0.0.0
network 192.168.0.0
network 192.168.20.0
network 192.169.20.0
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
05-19-2024 06:57 AM
my dumb mistake,
both interface facing to lan shouldn't have Ip, so the xconnect will complete
also need to configure l2tp-class
hope my mistake will help you guys... hehehehe this is for my fyp
