Licensing on C9200-24T
scariaso
We purchased, C9200-24T , that currently runs with evaluation license. It is understood that smart licensing should be enabled before expiry of eval licensing (starting with code 16.9.1) . However i would like to know what happens if i did not renew it, will it work with atleast LAN base?
C9200-24T #sh ver
Cisco IOS XE Software, Version 16.12.01
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT9K_LITE_IOSXE), Version 16.12.1, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Tue 30-Jul-19 18:12 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2019 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: System Bootstrap, Version 16.12.1r [FC2], RELEASE SOFTWARE (P)
akulcspa uptime is 12 minutes
Uptime for this control processor is 14 minutes
System returned to ROM by Image Install
System image file is "flash:packages.conf"
Last reload reason: Image Install
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-advantage Smart License network-advantage
dna-advantage Subscription Smart License dna-advantage
Smart Licensing Status: UNREGISTERED/EVAL MODE
cisco C9200-24T (ARM64) processor with 649643K/3071K bytes of memory.
Processor board ID XXXXXXXXXXXX
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4060228K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : XXXXXXXXXXXXXXXXX
Motherboard Assembly Number : XXXXXXXXXXXXXXX
Motherboard Serial Number : XXXXXXXXXXXXXX
Model Revision Number : C1
Motherboard Revision Number : B0
Model Number : C9200-24T
System Serial Number : XXXXXXXXXXXXX
Switch Ports Model SW Version SW Image Mode
* 1 32 C9200-24T 16.12.1 CAT9K_LITE_IOSXE INSTALL
Configuration register is 0x102
C9200-24T#
balaji.bandi
if the evaluation license expires the features will no longer will work.
EDIT :
depends on what license you have purchased base along with device - is perpetual. addition subscription will not work after evaluation expires
look at the below document in License section :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html#Licensing
BB
As far as I know this applies only to DNA licences, network essential or network advantage licenses are lifetime ones and never expires, as it's always been for all cisco ios devices.
However issueing a show license on a not registered device tells you "eval expired" or something like that, but features still works.
