moving VSM onto VEM distributed switch
markmills
Hi all,
I have a working nexus setup on two ESX hosts, with a VSM running on each host connected to a standard vSwitch.   VEM is installed and working and its all good.
Mod  Ports  Module-Type                      Model              Status
1    0      Virtual Supervisor Module        Nexus1000V         ha-standby
2    0      Virtual Supervisor Module        Nexus1000V         active *
3    248    Virtual Ethernet Module          NA                 ok
4    248    Virtual Ethernet Module          NA                 ok
We are now trying to move the two VSM's off the vSwitch and onto the distributed switch, but I must be doing something wrong!  The VSM is setup with the following VLANs:
334 - Packet
335 - Control
990 - Management
When we move both hosts onto the distributed switch, one of the VSM's drops its connection to all the VEM's, and the 2nd one goes into a constant reboot cycle.
The configuration on the VSM is as follows:
ip host edpswvsmdmz001 10.193.26.250
vlan 334
  name Packet
vlan 335
  name Control
vlan 990
  name Management
port-profile system-uplink
  capability uplink
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 334-335,990
  channel-group auto mode on
  no shutdown
  system vlan 334-335,990
  state enabled
port-profile trunk-uplink
  capability uplink
  vmware port-group
  switchport trunk allowed vlan all
  no shutdown
  state enabled
port-profile nexus-packet-v334
  vmware port-group
  switchport mode access
  switchport access vlan 334
  no shutdown
  state enabled
port-profile nexus-control-v335
  vmware port-group
  switchport access vlan 335
  no shutdown
  state enabled
port-profile nexus-management-v990
  vmware port-group
  switchport access vlan 990
  no shutdown
  state enabled
interface Ethernet3/2
  inherit port-profile system-uplink
interface Ethernet3/4
  inherit port-profile trunk-uplink
interface Ethernet4/2
interface Ethernet4/3
Now these are uplinked into a 3750.. the config on that is as follows:
interface Port-channel1
description vmh001-uplink
switchport nonegotiate
logging event trunk-status
logging event status
spanning-tree link-type point-to-point
end
interface Port-channel2
description vmh002-uplink
end
interface Port-channel11
description vmh001-system
switchport trunk allowed vlan 334,335,990
end
interface Port-channel12
description vmh002-system
Can anyone tell me what I am doing wrong here?
Cheers,
  Mark
Robert Burns
Are you moving one VSM at a time?
Move the standby VSM first, ensure they re-sync with "show sys red sta"
Then move the other one over.
Also, you did the right thing with making your control/packet/management vlans as "system" vlans on your System-Uplink, but you need to also configure system vlans on the Port Profiles you're assigning to your VSM interfaces.  Missing config shown in RED
  vmware port-group
  system vlan 334
  no shutdown
  state enabled
  vmware port-group
  system vlan 335
  no shutdown
  state enabled
  vmware port-group
  system vlan 990
  no shutdown
  state enabled
Robert
markmills
Hi Robert... adding in those three lines fixed the problem.
I knew it would be something simple!
Thankyou so much for your assistance.
