N2k fex setup in single unit parent swtich no VPC
yong khang NG
Level 5
Level 5
Hi All,
Kindly refer attached topology, there's only single parent unit N5K with no VPC setup, this is by adding 2 unit of FEX, act as line card, each fex uisng one port doing static pinning to parent switch, swithcport is connect to remote fabric interconnect switch
My objective is to connect fabric interconnect by using single port-channel span across FEX 101 (4 port) AND FEX 102 (4 port), ain't my concept illustrate on the drawing topology correctly present?
Feel free to comment , thanks
Noel
Remi Astruc
