N3K MIB's
Guy Greenshtein
Hi guys,
I was wondering if there's an option to download all the MIB's of a specific N3K model - C31128PQ.
I know there is an option to run snmp-walk but this is not an option right now.
David Castro F.
Hello Guy Greenshtein,
I hope you are doing great, below you will find an image with all the supported Management Information based (MIBs) by the specific model n3k:
Description
Specification
MIB support
Generic MIBs
●  SNMPv2-SMI
●  CISCO-SMI
●  SNMPv2-TM
●  SNMPv2-TC
●  IANA-ADDRESS-FAMILY-NUMBERS-MIB
●  IANAifType-MIB
●  IANAiprouteprotocol-MIB
●  HCNUM-TC
●  CISCO-TC
●  SNMPv2-MIB
●  SNMP-COMMUNITY-MIB
●  SNMP-FRAMEWORK-MIB
●  SNMP-NOTIFICATION-MIB
●  SNMP-TARGET-MIB
●  SNMP-USER-BASED-SM-MIB
●  SNMP-VIEW-BASED-ACM-MIB
●  CISCO-SNMP-VACM-EXT-MIB
●  CISCO-CLASS-BASED-QOS-MIB
Ethernet MIBs
●  CISCO-VLAN-MEMBERSHIP-MIB
●  LLDP-MIB
●  IP-MULTICAST-MIB
Configuration MIBs
●  ENTITY-MIB
●  IF-MIB
●  CISCO-ENTITY-EXT-MIB
●  CISCO-ENTITY-FRU-CONTROL-MIB
●  CISCO-ENTITY-SENSOR-MIB
●  CISCO-SYSTEM-MIB
●  CISCO-SYSTEM-EXT-MIB
●  CISCO-IP-IF-MIB
●  CISCO-IF-EXTENSION-MIB
●  CISCO-NTP-MIB
●  CISCO-IMAGE-MIB
  CISCO-IMAGE-UPGRADE-MIB
Monitoring MIBs
●  NOTIFICATION-LOG-MIB
●  CISCO-SYSLOG-EXT-MIB
●  CISCO-PROCESS-MIB
●  RMON-MIB
●  CISCO-RMON-CONFIG-MIB
●  CISCO-HC-ALARM-MIB
Security MIBs
●  CISCO-AAA-SERVER-MIB
●  CISCO-AAA-SERVER-EXT-MIB
●  CISCO-COMMON-ROLES-MIB
●  CISCO-COMMON-MGMT-MIB
●  CISCO-SECURE-SHELL-MIB
Miscellaneous MIBs
●  CISCO-LICENSE-MGR-MIB
●  CISCO-FEATURE-CONTROL-MIB
●  CISCO-CDP-MIB
●  CISCO-RF-MIB
Layer 3 and Routing MIBs
●  UDP-MIB
●  TCP-MIB
●  OSPF-MIB
●  BGP4-MIB
●  CISCO-HSRP-MIB
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-31128pq-switch/datasheet-c78-734585.html
You can locate them and download them in the following link:
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseMIB.do?local=en
Let me know if this suffice,
Please rate all of the helpful answers!
David Castro,
David Castro F.
Description
Specification
MIB support
Generic MIBs
●  SNMPv2-SMI
●  CISCO-SMI
●  SNMPv2-TM
●  SNMPv2-TC
●  IANAifType-MIB
●  HCNUM-TC
●  CISCO-TC
●  SNMPv2-MIB
●  SNMP-TARGET-MIB
Ethernet MIBs
●  LLDP-MIB
●  IP-MULTICAST-MIB
Configuration MIBs
●  ENTITY-MIB
●  IF-MIB
●  CISCO-SYSTEM-MIB
●  CISCO-IP-IF-MIB
●  CISCO-NTP-MIB
●  CISCO-IMAGE-MIB
Monitoring MIBs
●  CISCO-PROCESS-MIB
●  RMON-MIB
Security MIBs
Miscellaneous MIBs
●  CISCO-CDP-MIB
●  CISCO-RF-MIB
●  UDP-MIB
●  TCP-MIB
●  OSPF-MIB
●  BGP4-MIB
●  CISCO-HSRP-MIB
David Castro,
