05-25-2020 08:34 PM
We have a N3K-C3524P-XL with 24 port enable by default; And we need additional 24 port license recently.
How do we apply the license? using command install license xxx is ok? and do we need reboot the box, or do we need downtime?
05-25-2020 10:46 PM
Hi @yangui319
Yes, install license x is the command you need to use.
show license usage can help you verify the status of your switch licenses.
Regarding reboot of the switch, I am not entirely sure, but I think yes, a reload will be needed.
Sergiu
05-25-2020 11:04 PM
Thanks for your reply
because the device is in production environment, we have concern about reboot the box
05-26-2020 11:55 PM
You can install the license. If there is need for reload, you will be prompted with a message, and you can do the manual reboot anytime you want. if you do not see any prompt, and the ports are available to use, then no need for reload.
Stay safe,
Sergiu
05-27-2020 12:04 AM
year, that's right
If need reboot, we need apply for downtime
