N5K-C5548P Fan
kmblanco8
Hello Guys. We have raised an RMA for N5548P-FAN as we are receiving alarms on fan tray 2. However, we do not know which one is fan tray 2 so we cannot proceed with the replacement. Issue is intermittent, and we cannot monitor the LED status. Looking at the rear of the switch, does fan tray count starts from the left, i.e., fan tray 2 is the one on the right, beside the PSU? Thank you for the help
marce1000
 - Remove a (the) fan tray shortly and re-insert , then check console or device logs , the fan tray which you handled will be reported together with it's number ,
 M.
Hello Marce. Thank you. We will try that
