N9K-C93180YC-FX / N9K-C93180YC-FX and monitor session not working
artfulcisco
Software 9.3.3
create new monitor session
(config)# monitor session 2
(config-monitor)# source interface ethernet 1/38
(config-monitor)# destination interface Ethernet1/46
(config-monitor)# no shut
(config-monitor)# exit
description monitor
switchport
switchport monitor
no shutdown
monitor session 2
source interface Ethernet1/38 both
after me check working monitor session
how monitor session 2
session 2
type : local
state : down (Session admin shut)
why me insert command - no shut in monitor session
and monitor session still - shutdown ???
no any log
help please, how to up monitos session. command "no shut' not working !!!
8 Replies 8
Sergiu.Daniluk
1. Are source and destination ports admin up?
2. How many other SPAN sessions you have configured?
3. Do you see any errors in the 'show logging log' during the time of the configuration?
4. Do you see any FAILED commands in the 'show accounting log' during the time of the configuration?
Cheers,
Sergiu
1. yes
Eth1/38 -- connected trunk full 10G SFP-H10GB-CU2M
Eth1/46 monitor connected 1 full 10G SFP-H10GB-CU3M
show running-config monitor
!Command: show running-config monitor
!Running configuration last done at: Sun Apr 26 22:23:16 2020
!Time: Mon Apr 27 00:42:25 2020
version 9.3(3) Bios:version 07.66
monitor session 1
2. one span session
3. no any error log
4.
Sun Apr 26 22:23:10 2020:type=update:id=192.168.0.1@pts/0:user=admin:cmd=configure terminal ; monitor session 1 (SUCCESS)
Sun Apr 26 22:23:14 2020:type=update:id=192.168.0.1@pts/0:user=admin:cmd=configure terminal ; monitor session 1 ; source interface Ethernet1/38 (SUCCESS)
Sun Apr 26 22:23:16 2020:type=update:id=192.168.0.1@pts/0:user=admin:cmd=configure terminal ; monitor session 1 ; no shut (SUCCESS)
no error
Can you share the full output of show monitor session 1?
Sergiu
   session 1
type              : local
acl-name          : acl-name not specified
source intf       :
    rx            : Eth1/38
    tx            : Eth1/38
    both          : Eth1/38
source VLANs      :
    rx            :
    tx            :
    both          :
filter VLANs      : filter not specified
source fwd drops  :
destination ports : Eth1/46
source VSANs      :
    rx            :
I had the same problem but in my case Netflow (sflow) was configured on my Nexus switch. On Cisco Nexus 9300-EX/FX/FX2 platform switches, SPAN, and sFlow cannot both be enabled simultaneously. If one is active, the other cannot be enabled. Remove slfow configuration or disable feature sflow .
artfulcisco
Please help,  nexus 3064 working fine, nexus 93180 not working
me found
me downgrade NX-OS to nxos.7.0.3.I7.8.bin
switch(config)# sflow data-source interface ethernet 1/3
switch(config)# monitor session 1
switch(config-monitor)# no shut
ERROR: SFLOW is configured. Please delete all SFLOW data sources before configuring SPAN sessions
if me install nxos.9.3.3.bin - no error message if me try enable monitor session
on Nexus N9K-C9396PX sflow and port mirroring work together
From 7.x system management config guide:
On Cisco Nexus 9300-EX/FX/FX2 platform switches, and Cisco Nexus 9500 platform switches with EX/FX modules, SPAN and sFlow cannot both be enabled simultaneously. If one is active, the other cannot be enabled. However, on the Cisco Nexus 9300-EX/FX/FX2 and the Cisco Nexus 9500 platform switches with EX modules, both Netflow and SPAN can both be enabled simultaneously, providing a viable alternative to using Sflow and SPAN.
In 9.x system management guide:
On Cisco Nexus 9300-EX/FX platform switches, SPAN and sFlow cannot both be enabled simultaneously. If one is active, the other cannot be enabled. However, on the Cisco Nexus 9300-EX/FX/FX2, both NetFlow and SPAN can both be enabled simultaneously, providing a viable alternative to using sFlow and SPAN.
Note
Cisco Nexus 9300-FX2 switches support sFlow and SPAN co-existence.
The following Cisco Nexus switches support sFlow and SPAN together:
  • N9336C-FX2
  • N93240YC-FX2
  • N93360YC-FX2
