N9K1 N9K2
FEX121 FEX122
eth0--C240--eth1
Using vPCs go through FEX and using port-channel 200 to connect the independant Server (C240)
On N9K1 and On N9K2, type "Show mad address interface port-channel 200", found the both sides only detected a same mac address from eth0 itself
I do know what wrong is . Login to CIMC, there are no where can setup "Port-channel" for the both NICs (eth0,eth1)
Any idea? Thank you for help !
sam wang
