Netflow on a Nexus 5672UP sending incorrect InputInt and OutputInt.
jay.colby
Hello All,
I am seeing several Nexus 5672UP send the incorrect input and output interface identity.  I am using SolarWinds as a SNMP and Netflow collector.  I am seeing from and SNMP walk and show command that the correct SNMP identifier match in the SolarWinds data base.  I am getting correct stats from SNMP.  What is the issue is Netflow.  I am seeing from a Wireshark capture the switch is sending a different identifiers as SNMP.  So, SolarWinds see this as an monitored interface.
I do not think this is a bug as it has followed incremental and major code versions.  Same for SolarWinds.
Current enviroment:
SolarWinds:
NPM -12.3
NTA - 4.4
Nexus:
kickstart: version 7.3(3)N1(1)
system: version 7.3(3)N1(1)
jay.colby
This is fixed.  On a hunch I configured neflow to use version 9.  It resolved my issue.
version 7.3(3)N1(1)
feature netflow
flow exporter FLOWEXP-1
destination 10.100.4.40
transport udp 2055
source Vlan3
version 9
flow record IPv4Flow
description Ipv4flow
match transport destination-port
collect counter packets
sampler Sampler
mode 1 out-of 128
flow monitor FLOW-MONITOR-1
record netflow-original
exporter FLOWEXP-1
interface Vlan2
ip flow monitor FLOW-MONITOR-1 input sampler Sampler
jay.colby
jay.colby
version 7.3(3)N1(1)
feature netflow
transport udp 2055
source Vlan3
version 9
sampler Sampler
mode 1 out-of 128
exporter FLOWEXP-1
interface Vlan2
Should the config for interface vlan be configured for VLAN3 instead of VLAN2?
