11-07-2022 01:19 AM
Planning to migrate nexus N5K-C5672UP to N9K-C93180YC-FX no extra configuration is needed just need to copy and paste old config to new nexsus 9k switch .My question is there any checklist to perform this acitivity orelse i can go with pulg and play?
Solved! Go to Solution.
11-08-2022 03:16 AM
If you mean have a vPC domain with one peer as N5K and another with N9K, then no. You cannot do that.
11-08-2022 02:43 AM
Hi @Mani G
Usually, when I perform similar migrations, there are several things I check:
- the current STP root and what implications are when I add the new switch
- I save the MAC and ARP tables for multiple checks (number of entries, how endpoints are learned and on which ports)
- interface status before and after migration (which are up before and after)
- port-channel status (if LACP is configured) before and after migration
- if routing is configured - routing table and routing adjacencies before and after migration
Basically, I am taking a snapshot of the current state of the switch and network before migration, and compare it with after migration.
Hope it helps,
Sergiu
11-08-2022 02:57 AM
Thanks! Can i pair vPC between Nexus5K and Nexus9K while migration.
11-08-2022 03:16 AM
