Nexus 1000v Uplink port Blocked by admin
Ben93160_4
I recently install and configure a Nexus 1000v!
I migrate a server on a vlan dedicated with an adapted port-profile (access vlan).
I can ping this server but someting trouble me : when I go to the configuration tab of my switch I can see that my server's port is green (up and not blocked) and showing the right vlan ID but the uplink port is grey and blocked by admin :
I think ping works because it uses the system VLAN but other flow will not pass.
Can someone explain me why the port is in grey and how could I unblock this port.
Thanks a lot for your help ans sorry for mistakes, I'm a french student.
Benoit
lwatta
It's hard to tell based just off your description.
Can you post your running config? We should be able to tell whats going on after looking at the configuration.
louis
swi-nexus1000v-scl01# show running-config
!Command: show running-config
!Time: Mon Apr 29 12:09:16 2013
version 4.2(1)SV1(5.2b)
no feature telnet
username admin password 5 $1$k1qdCY94$cPRwMWLH2NBShx0IvGIH8.  role network-admin
banner motd #Nexus 1000v Switch#
ip domain-lookup
ip host swi-nexus1000v-scl01 10.34.13.65
switchname swi-nexus1000v-scl01
errdisable recovery cause failed-port-state
vem 3
  host vmware id bd56b0aa-93cf-ed46-86b3-65ad9fa72a81
snmp-server user admin network-admin auth md5 0x90495ef2cf28f8151ece16eb23affcf7 priv 0x90495ef2cf28f8151ece16eb23affcf7 localizedkey
snmp-server community public group network-operator
ntp server 10.25.22.30
vrf context management
  ip route 0.0.0.0/0 10.34.13.1
vlan 1,1000,1004,1063
vlan 1
vlan 1000
  name VLAN-PROD-1000
vlan 1004
  name VLAN-NETWAF-1004
vlan 1063
  name VLAN-ADMIN-1063
port-channel load-balance ethernet source-mac
port-profile default max-ports 32
port-profile type ethernet Unused_Or_Quarantine_Uplink
  vmware port-group
  shutdown
  description Port-group created for Nexus1000V internal usage. Do not use.
  state enabled
port-profile type vethernet Unused_Or_Quarantine_Veth
  vmware port-group
  shutdown
  state enabled
port-profile type vethernet ADMIN-VMWARE-1063
  vmware port-group
  switchport mode access
  switchport access vlan 1063
  no shutdown
  state enabled
port-profile type ethernet NEX-UPLINK-1
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 1000,1004,1063
  no shutdown
  system vlan 1063
  state enabled
port-profile type vethernet NET-WAF-1004
  vmware port-group
  switchport access vlan 1004
  no shutdown
  state enabled
port-profile type vethernet VLAN-PROD-1000
  vmware port-group
  switchport access vlan 1000
  no shutdown
  state enabled
port-profile type vethernet PP-DATA
  vmware port-group
  no shutdown
  state enabled
port-profile type vethernet PP-HA
  vmware port-group
  no shutdown
  state enabled
vdc swi-nexus1000v-scl01 id 1
  limit-resource vlan minimum 16 maximum 2049
  limit-resource monitor-session minimum 0 maximum 2
  limit-resource vrf minimum 16 maximum 8192
  limit-resource port-channel minimum 0 maximum 768
  limit-resource u4route-mem minimum 1 maximum 1
  limit-resource u6route-mem minimum 1 maximum 1
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
interface mgmt0
  ip address 10.34.13.65/25
interface Vethernet1
  inherit port-profile VLAN-PROD-1000
  description tdmtrp11s, Network Adapter 1
  vmware dvport 100 dvswitch uuid "89 a0 0f 50 a6 8c a5 d2-cc 6d 90 5e dd 64 21 26"
  vmware vm mac 0050.568F.6144
interface Vethernet2
  inherit port-profile ADMIN-VMWARE-1063
  description nexus1000v-vnmc-scl01, Network Adapter 1
  vmware dvport 32 dvswitch uuid "89 a0 0f 50 a6 8c a5 d2-cc 6d 90 5e dd 64 21 26"
  vmware vm mac 0050.568F.2521
interface Vethernet3
  inherit port-profile PP-HA
  description nexus1000v-vsg-scl01, Network Adapter 3
  vmware dvport 192 dvswitch uuid "89 a0 0f 50 a6 8c a5 d2-cc 6d 90 5e dd 64 21 26"
  vmware vm mac 0050.568F.2529
interface Vethernet4
  inherit port-profile PP-DATA
  description nexus1000v-vsg-scl01, Network Adapter 1
  vmware dvport 224 dvswitch uuid "89 a0 0f 50 a6 8c a5 d2-cc 6d 90 5e dd 64 21 26"
  vmware vm mac 0050.568F.2527
interface Ethernet3/4
  inherit port-profile NEX-UPLINK-1
interface control0
line console
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV1.5.2b.bin sup-1
boot system bootflash:/nexus-1000v.4.2.1.SV1.5.2b.bin sup-1
boot kickstart bootflash:/nexus-1000v-kickstart.4.2.1.SV1.5.2b.bin sup-2
boot system bootflash:/nexus-1000v.4.2.1.SV1.5.2b.bin sup-2
svs-domain
  domain id 1
  control vlan 1063
  packet vlan 1063
  svs mode L2
svs connection vcenter
  protocol vmware-vim
  remote ip address 10.34.13.13 port 80
  vmware dvs uuid "89 a0 0f 50 a6 8c a5 d2-cc 6d 90 5e dd 64 21 26" datacenter-name Test
  max-ports 8192
  connect
vservice global type vsg
  tcp state-checks
vnm-policy-agent
  registration-ip 10.34.13.66
  shared-secret **********
  policy-agent-image bootflash:/vnmc-vsmpa.2.0.1b.bin
  log-level
Sorry, it looks like your post got stuck and just showed up.
I don't see anything wrong with your configuration. When you say that pings work but other flows do not can you explain a little more?
It looks like you are migrating your Vmware mgmt interface to the Nexus 1000V. Is that correct? if so as long as you can ping the interface and the host still shows up under vcenter it should be working.
There are a few bugs filed against the nexus 1000v for not displaying the correct vlan information in vCenter.
louis
